FPGA Intellectual Property
6369 Discussions
Megafunctions Mega Wizard Plug-Ins Manager problem
Hello I recently installed Quartus II v 8.1 and I've been having trouble using the Mega Wizard.
The problem is that when I try to use the Altera OpenCore Plus IP in the MegaWizard, the only thing I get is the IP MegaStore and it shows that there are no installed plug ins.
I already tried re-installing and made sure that I chose Typical installation.
I'm attaching a screenshot of what I see while using the Mega Wizard. I hope someone can solve this problem.
is the QUARTUS_ROOTDIR environment variable set to the quartus directory of your 8.1 install?
Interesting window manager ... Are you actually running a supported OS?
Jake
