50/60Hz Digital PLL
hpola3
We want to implement a digital 50/60Hz PLL for synchronisation purpose.
We want to replace an old HEF4046B IC.
Is it possible to design a 50/60Hz with FPGA/CPLD (MAX10 family i.e)? do you have any reference design?
Rahul_S_Intel1
Hi ,
You can use PLL for the generation
Rahul_S_Intel1
Hi ,
Kindly let me know , if you need further assistance.
Rahul S
hpola3
Hi Rahus,
In Max10 internal PLLs minimum frequency range is in MHz range.
I need a PLL for 50/60Hz application (grid frequency lock). Also PLLs has a filter which adjust its slew rate and speed.
Do you think is it possible with Max10 family? Do you have an IP of reference design for such application?
Rahul_S_Intel1
Hi ,
May I know the below suggestion will work or not .
Implement a counter , where you know the input frequency and make the counter to your desired clock out put . I find my code may be it will be useful for you .
library IEEE;
use IEEE.NUMERIC_STD.all;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity scale_clock is
 port (
  clk_50Mhz : in std_logic;
  rst    : in std_logic;
  clk_2Hz  : out std_logic
end scale_clock;
architecture Behavioral of scale_clock is
 signal prescaler : unsigned(23 downto 0);
 signal clk_2Hz_i : std_logic;
begin
 gen_clk : process (clk_50Mhz, rst)
 begin -- process gen_clk
  if rst = '1' then
   clk_2Hz_i  <= '0';
   prescaler  <= (others => '0');
  elsif rising_edge(clk_50Mhz) then  -- rising clock edge
   if prescaler = X"BEBC20" then   -- 12 500 000 in hex
    clk_2Hz_i  <= not clk_2Hz_i;
   else
    prescaler <= prescaler + "1";
   end if;
end if;
 end process gen_clk;
clk_2Hz <= clk_2Hz_i;
end Behavioral;
Rahul_S_Intel1
Hi ,
Kindly let me know if you need further assistance
