I Created design based on DPX4 5.4GHz. The example design includes 'dp_gxb_sysclk' module. According to Ip generation the reference clock supposed to be 150Mhz. I created simulation based on this design and it seems that the pll doesn't lock and no ref_clock or sys_clock is driven at the pll outputs. I will appricate If I can get help on this subject.
The device is Aglilex-7.
Elad Rotem
We will look into your PLL setting first.
- Do you have design example we can check your PLL parameters?
- If you reduce the output clock speed- can it lock?
possible cause PLL wont lock:
a. VCC to PLL not stable - need to capture scope shot
b. unstable refclk - need to capture scopeshot
c. PLL reset signal triggered - need to check schematic
regards,
Farabi
Hi Farabi,
Thank you for your response. The model I have issue is simulation and not lab test.
In simulation the pll doesn't lock or drive any clock at his outputs.
Elad
May I know which example design that you are referring to? Can you pointed out to us?
Aqid
DisplayPort using Agilex-7 Device.
Elad
Hi Elad,
Is this from the IP simulation example itself as link below?
https://www.intel.com/content/www/us/en/docs/programmable/683273/23-3-20-0-1/simulation-example.html
It will be helpful if you can share the link pointing to the design that you mentioned.
Aqid
Hi Aqid,
The link you mention is for Arria V, Cyclone V, and Stratix V. I don't see any support for Agilex-7. Also, it only supports Modelsim.
I created the DisplayPort IP from the Quartus and then press on 'create example design'.
Elad
Hi Elad,
Are you following the steps outlined in Section 1.3 of the User Guide below to generate the Design Example for the DisplayPort Intel FPGA IP?
Please note that in this release, simulation is not yet supported for Agilex™ 7 F-Tile devices.
F-Tile DisplayPort Intel® FPGA IP Design Example User Guide
Ven
Hi Elad,
Do you have further questions on this thread?
Ven
