I'm not able to get the Altera's Ethernet Example Design to work on the Cyclone III Dev. Board. I used the "Using the NicheStack TCP/IP Stack - Nios II Edition Tutorial".
PHY INFO: 0x12 141 cc2
PHY INFO: Issuing PHY Reset
PHY INFO: waiting on PHY link...
PHY INFO: PHY link detected, allowing network to start.
SSS INFO: Connecting...
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
prep_tse_mac 0
Your Ethernet MAC address is 00:07:ed:08:xx:xx
prepped 1 interface, initializing...
INFO : TSE MAC 0 found at address 0x0800a000
INFO : PHY Marvell 88E1111 found at PHY address 0x12 of MAC Group
INFO : PHY - Automatically mapped to tse_mac_device
INFO : PHY - Restart Auto-Negotiation, checking PHY link...
INFO : PHY - Auto-Negotiation PASSED
INFO : PHY - Checking link...
INFO : PHY - Link established
INFO : PHY - Speed = 1000, Duplex = Full
OK, x=48, CMD_CONFIG=0x00000000
MAC post-initialization: CMD_CONFIG=0x0400020b
RX descriptor chain desc (1 depth) created
mctest init called
IP address of et1 : 134.130.xxx.xxx
Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
DHCP timed out, going back to default IP address(es)
Nios II Simple Socket Server starting up.
Created "monitor_phy" task (Prio: 9)
Created "Nios II Simple Socket Server" task (Prio: 10)
Nios II Simple Socket Server listening on port 30
The DHCP isn't working, I cannot ping the board and telnet isn't working. In a next step I set the IP to a static one -> the same effect. I got the same effect for the example templates in Nios2-Eclipse. I checked the same design with the NEEK board and it runs well (naturally the .sof for the NEEK) with the original flash-file (the application selector) and the niosii_ethernet_standard_3c25.sof overloading. Using another flash-content, it also doesn't work like the 3C120. Any idea? Best Regards Mark
Is the static IP in the same subnet as the computer you use to ping?
yes, it is.
--- Quote Start --- Hi, I'm not able to get the Altera's Ethernet Example Design to work on the Cyclone III Dev. Board. I used the "Using the NicheStack TCP/IP Stack - Nios II Edition Tutorial".
prep_tse_mac 0
mctest init called
The DHCP isn't working, I cannot ping the board and telnet isn't working. In a next step I set the IP to a static one -> the same effect. I got the same effect for the example templates in Nios2-Eclipse. I checked the same design with the NEEK board and it runs well (naturally the .sof for the NEEK) with the original flash-file (the application selector) and the niosii_ethernet_standard_3c25.sof overloading. Using another flash-content, it also doesn't work like the 3C120. Any idea? Best Regards Mark --- Quote End --- seeing your output it seems that u r hardware is not taking ip address. go to the simple_socket_server.h file and give your IP address + if you don't have DHCP server, through network_utilities.c file disable it (*use_dhcp = 0)
I marked the last two bytes of the IP and the MAC with "x", because the IP is in a public subnet.
I disabled DHCP and also tested the design in a private subnet (192.168.123.001 255.255.255.000) with no change.- Mark as New
The hardware doesn't work. I believe timing constrains are wrong or there are none.
@Socrates:
It's the original .sof-file from Altera. So it should work, or not? @all is there anyone who has an ethernet design running for the 3c120f780 Cyclone III dev board and can send it to me? Best Regards- Mark as New
Did you disable DHCP in the NicheStack properties?
Please post again the console log with DHCP disabled.- Mark as New
I set "dhcp=0" in iniche_init.c (line line 341)
again no ping.
prep_tse_mac 0
Your Ethernet MAC address is 00:07:ed:08:1a:2a
OK, x=4, CMD_CONFIG=0x00000000
mctest init called
IP address of et1 : 192.168.123.2
--- Quote Start --- I set "dhcp=0" in iniche_init.c (line line 341) --- Quote End --- I'm not sure this assignment will really disable dhcp. You should disable it in bsp iNiche properties or remove the DHCP_CLIENT define inside ipport.h
Disabling DHCP-Server in BSP-Editor->Software packages results in 3 errors:
Description Resource Path Location Type make: *** [niosII_Simple_Socket_Server_ohne_DHCP.elf] Error 1 niosII_Simple_Socket_Server_ohne_DHCP C/C++ Problem Description Resource Path Location Type undefined reference to `dhc_set_callback' iniche_init.c /niosII_Simple_Socket_Server_ohne_DHCP line 509 C/C++ Problem Description Resource Path Location Type undefined reference to `dhc_set_state' iniche_init.c /niosII_Simple_Socket_Server_ohne_DHCP line 483 C/C++ Problem- Mark as New
IIRC there is something special to do to set up the interface in rgmii mode, as it is on the 3C120 kit. I don't remember it exactly but a search on the forum could help.
Looking in the software templates in Quartus 10.1 they seem to have created special rgmii templates, maybe you can try those.- Mark as New
I tried out the SimpleSocketServer_RGMII and this one is running. It seems so, that the 3C120 Dev Board needs a RGMII-Design in Nios. Thanks a lot to Daixiwen! You gave me the special tip. Possibly Altera adds the RGMII code to the 3c120-board tuturial. Best Regards Mark- Mark as New
To anyone who's curious, I think this was the solution:
http://www.altera.com/support/kdb/solutions/rd11122009_293.html- Mark as New
This a all things you need, If it help for you. Thanks to me so much
I done- Mark as New
error_t generate_mac_addr(unsigned char mac_addr[6])
{ error_t error = -1; alt_u32 ser_num = 0; printf("\nCan't read the MAC address from your board. We will assign you\n"); printf("a MAC address.\n\n"); ser_num = get_serial_number(); if (ser_num) { /* This is the Altera Vendor ID */ mac_addr[0] = 0x0; mac_addr[1] = 0x7; mac_addr[2] = 0xed; /* Reserverd Board identifier */ mac_addr[3] = 0xFF; mac_addr[4] = (ser_num & 0xff00) >> 8; mac_addr[5] = ser_num & 0xff; printf("Your Ethernet MAC address is %02x:%02x:%02x:%02x:%02x:%02x\n", mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]); error = 0; } return error; } /* * get_board_mac_addr * * Read the MAC address in a board specific way * */ error_t get_board_mac_addr(unsigned char mac_addr[6]) { error_t error = 0; alt_u32 signature; if (!error) { signature = IORD_32DIRECT(last_flash_sector, 0); if (signature != 0x00005afe) { error = generate_and_store_mac_addr(); } } if (!error) { mac_addr[0] = IORD_8DIRECT(last_flash_sector, 4); mac_addr[1] = IORD_8DIRECT(last_flash_sector, 5); mac_addr[2] = IORD_8DIRECT(last_flash_sector, 6); mac_addr[3] = IORD_8DIRECT(last_flash_sector, 7); mac_addr[4] = IORD_8DIRECT(last_flash_sector, 8); mac_addr[5] = IORD_8DIRECT(last_flash_sector, 9); printf("Your Ethernet MAC address is %02x:%02x:%02x:%02x:%02x:%02x\n", mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]); } return error; } /* * get_mac_addr * * Read the MAC address in a board specific way * */ int get_mac_addr(NET net, unsigned char mac_addr[6]) { error_t error = 0; error = get_board_mac_addr(mac_addr); if(error) { /* Failed read MAC address from flash, prompt user to enter serial number to generate MAC address. */ error = generate_mac_addr(mac_addr); } return error; } /* * get_ip_addr() * * This routine is called by InterNiche to obtain an IP address for the * specified network adapter. Like the MAC address, obtaining an IP address is * very system-dependant and therefore this function is exported for the * developer to control. * * In our system, we are either attempting DHCP auto-negotiation of IP address, * or we are setting our own static IP, Gateway, and Subnet Mask addresses our * self. This routine is where that happens. */ int get_ip_addr(alt_iniche_dev *p_dev, ip_addr* ipaddr, ip_addr* netmask, ip_addr* gw, int* use_dhcp) { IP4_ADDR(*ipaddr, IPADDR0, IPADDR1, IPADDR2, IPADDR3); IP4_ADDR(*gw, GWADDR0, GWADDR1, GWADDR2, GWADDR3); IP4_ADDR(*netmask, MSKADDR0, MSKADDR1, MSKADDR2, MSKADDR3); # ifdef DHCP_CLIENT *use_dhcp = 1; # else /* not DHCP_CLIENT */ *use_dhcp = 0; printf("Static IP Address is %d.%d.%d.%d\n", ip4_addr1(*ipaddr), ip4_addr2(*ipaddr), ip4_addr3(*ipaddr), ip4_addr4(*ipaddr)); # endif /* not DHCP_CLIENT */ /* Non-standard API: return 1 for success */ return 1; } /******************************************************************************* * * Flash service functions. * ******************************************************************************/ # include "sys/alt_flash.h" # include "sys/alt_flash_dev.h" /* * FindLastFlashSectorOffset * * <-- pLastFlashSectorOffset Offset of last sector in flash. * * This function finds the offset to the last sector in flash and returns it * in pLastFlashSectorOffset. */ int FindLastFlashSectorOffset( alt_u32 *pLastFlashSectorOffset) { alt_flash_fd *fd; flash_region *regions; int numRegions; flash_region *pLastRegion; int lastFlashSectorOffset; int n; int error = 0; /* Open the flash device. */ fd = alt_flash_open_dev(EXT_FLASH_NAME); if (fd <= 0) error = -1; /* Get the flash info. */ if (!error) error = alt_get_flash_info(fd, ®ions, &numRegions); /* Find the last flash sector. */ if (!error) { pLastRegion = &(regions[0]); for (n = 1; n < numRegions; n++) { if (regions[n].offset > pLastRegion->offset) pLastRegion = &(regions[n]); } lastFlashSectorOffset = pLastRegion->offset + pLastRegion->region_size - pLastRegion->block_size; } /* Return results. */ if (!error) *pLastFlashSectorOffset = lastFlashSectorOffset; return (error); }- Mark as New
in addition, You can post up a code that you defined your IP to ping. and I can test helping for you. I'm also related to my topic.
Above all, You should test define in "simple_socket_server.h"
there a numerous at "web_server.h" in addition, I think that define for IP address have a problem. please posted full code it will show how code error.- Mark as New
Hi all,
i got a NEEK 3c25 board, i've followed instructions step by step but at the end when i launch Eclipse project the console output get stuck with: PHY INFO: waiting on PHY link... and nothing happens, no IP is assigned to the board and lights on Ethernet connector of the NEEK board remains on with no blinking. If i attach/detach ethernet plug to NEEK board it's the same.. My configuration is PC LAN with DHCP and NEEK LAN connected to a switch. I've tried also to uncheck dhcp in BSD properties but this action lead to impossility to compile eclipse project i have a lot of errors...- Mark as New
Hi Mark,
May be this thread is too old. But I am also stuck with the same problem now. I have a relatively old Cyclone III FPGA board, bought in 2009 I think. It could not run the "simple_socket_server_rgmii" example provided in "altera\12.1\nios2eds\examples\software". It cannot run even the recently downloaded example from: http://www.altera.com/support/examples/nios2/exm-using-nichestack.html . I added -DTSE_MY_SYSTEM flag and also commented out "IOWR(&pmac->mdio1.reg14, 0, dat); " line as suggested here: http://www.niosii.com/support/kdb/solutions/rd01042012_567.html The "tse_my_system.c" file is already provided in the recent example with the necessary code. Do you have any idea what might have gone wrong? Do I need to change any settings on my computer? Thanks,
