6357 Discussions
MAX 10 - Internal ADCs - analog inputs configuration
Amir3
We want to run the internal ADCs on the 10M25DAF256I7G FPGA.
In this device, there are 2 dedicate analog inputs called "ANAIN1" and "ANAIN2", and 16 pins for analog input or I/O (under bank 1A) called "ADC[1..2]IN[1..8]".
The plan is to use part of the 16 pins as analog input and the other as I/O.
ADC_VREF = 2.5[v]
VCCIO1A = 3.3[v]
Note - In our design, all I/Os should be configured as "3.3-V LVTTL".
Is this design correct?
Mengzhe
  • For 'The plan is to use part of the 16 pins as analog input and the other as I/O'
As mentioned in Intel® MAX® 10 Analog to Digital Converter User Guide:
'If you use bank 1A for ADC, you cannot use the bank for GPIO.'
so other pins cannot be used as I/O.
  • ADC_VREF = 2.5[v]
That's right.
  • VCCIO1A = 3.3[v]
Refer to Intel® MAX® 10 FPGA Device Family Pin Connection Guidelines:
'If you enable the ADC feature, connect VCCIO1A and VCCIO1B to 2.5 V.'
Besides, for ADC, power supply VCCA_ADC and VCCINT are needed.
BR,
Mengzhe
