SocEDS SSH connect failure
I upgraded BuildRoot yesterday in order to gain OpenCV 3.0 support. However, the resulting Linux build results in a failure when attempting to connect to the board via SSH in the SocEDS remote connection prospective:
Session.connect: java.security.InvalidAlgorithmParameterException: Prime size must be multiple of 64, and can only range from 512 to 1024 (inclusive)
Looks like the upgraded SSL is using larger primes and in the process exposing a bug in the Eclipse Jsch plug-in. Anybody else trip over this one?
By the way - same problem with the new ARM DS-5 DS500-BN-0021-r5p0-21rel1 release.
And yet more info - Installed Eclipse Mars with JRE 1.8.0_51 (latest) and I can connect to my SoCKit with no problems. Looks like an update to DS-5/SocEDS from ARM/Altera will be needed to address this problem.
