Remote System Update (RSU) example on Cyclone IV GX development kit
cancel
Showing results for
Search instead for
Did you mean:
340 Discussions
Description
This is an example design of remote system update (RSU) for Cyclone IV GX development kit. This design is based on AN 521: Cyclone III Active Parallel Remote System Upgrade Reference Design.
The changes from the AN 521 reference design are as follows:
  • AP to AS in configuration scheme
  • Removed PFL
  • Changed Device and Pin options for AS
  • Perform all commands
  • Added some commands which are not performed in AN521 design
  • Changed design in ru_cb.v
  • See RSU Function slide for command list
  • Past Status 2 indicator
  • Added past status 2 indicator LEDs in Factory design
  • SignalTap II for Factory and Application
  • PLL setting
  • Added 100MHz output for SignalTap II sampling clock
  • Modified for Cyclone IV GX FPGA Development Kit
  • Assigned clock, user push buttons and user LEDs
See RSU Example CIV GX Wiki.pdf for detail.
Content
  • Project
File:RSU CIVGX devkit wiki f.zip
Added Conversion Setup File (.cof) into output_files of CIII_CIV_RU_FactoryImage
  • Instruction
File:RSU Example CIV GX Wiki.pdf
Version history
Last update:
‎06-26-2019 11:19 PM
Updated by:
Contributors
