For some reason, I couldnt reply to original post, but wanted to post this in case other individuals encounter this going forward. I purchased a new Lenova Thinkpad Windows 11 pro. When I open up Excel my yellow (RBG 255, 255, 0) is showing as a lime green. When I disable Intel ARc Pro Graphics adapter (driver version 32.0.101.6637), my yellow (RBG 255, 255, 0) is showing up correctly in Excel and Powerpoint, however I can't use multiple monitors so that isn't acceptable answer. I used the intel update to go to driver version 32.0.101.8132, but still had same issue. I uninstalled the device and restarted and my computer reinstalled driver 32.0.101.6637. My other display driver isntalled is for my NVIDIA GeForce RTX 4070 GPU - driver 32.0.15.7357 Night mode is off HDR is off Any recommendations After 3 calls to Lenovo and a call to Intel suppor, I was finally able to get to a very knowledgeable help desk staff at Lenovo. They noticed when they screen shared, the yellow showed up correctly on their screen, so it was a color profile setup issue. They guided me to the Intel Graphics command center. If you go to Display section and then the color section, it brings up the color profiles. He had me change my Contract enhancement up from 17 to 19, and that did the trick (For my preference). Had to do it on all 3 monitors. He said that he had a new laptop and had to spend about 30 minutes setting up each monitor to get it to your liking. I will make adjustments as I go, but made all the difference. Hopefully, this helps some individuals in the future if this occurs to them. Didn't get that feedback from 4 prior calls, or from Chatgpt specific prompting.
