GPU Compute Software
Ask questions about Intel® Graphics Compute software technologies, such as OpenCL* GPU driver and oneAPI Level Zero
523 Discussions
Incorrect DisplayPort version Arc A380 in Windows 11
Owleye
Two displays:
My desktop PC boots up with the board manufacture's logo on main monitor, I can use the EAUFI settings menu on that monitor just fine.
Once windows boots the monitor goes blank and displays a "Incorrect DisplayPort Version".
I have tried:
Setting the monitor to 1.2, it just states No Signal Present.  So back to 1.4
uninstalling and reinstalling the display on Device manager.  No effect.
The DM says Arc.
Swapping cables has no effect, using different ports on card no effect.
The ARC version is 31.0.101.5186
Monitors:  32BL75U -WA.AUBQNPN
Monitors work fine with a Dell laptop, and Windows Surface.
JayB_Intel
Hello Owleye,
Thank you for posting in the Intel® Communities Support.
I would like to clarify a few points so that we can provided appropriate and relevant support.
Did your system use to work before with your 2 monitors when using Arc A380? Or is this an out-of-box issue?
Any recent changes (hardware/software) made on the system?
Make the Above 4G Decoding and Re-Size BAR are supported by your motherboard and Enabled/Auto
For us to further understand the situation and also to help us diagnose the issue, we would like to request for your system scan via Intel SSU. Please follow our article below on how to generate the Intel SSU logs.
Jay B.
JayB_Intel
Hello Owleye,
Were you able to check the previous post? Let us know if you still need assistance.
Jay B.
JayB_Intel
Hello Owleye,
I hope you are doing well. Since we have not heard any feedback regarding our previous post, we will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Jay B.
