Hello Intel Support Team,
I would like to report a performance issue I am experiencing while playing Crossout on my PC.
When I play Crossout with Discord running in the background, I experience regular lag spikes approximately every 8 seconds. These lag spikes significantly affect gameplay, causing noticeable stuttering and frame time spikes.
If I close Discord completely, the issue disappears and the game runs smoothly with stable performance.
This behavior is 100% reproducible on my system and occurs only when Discord is open. It happens even if Discord is minimized and no voice channel is actively being used.
Additional notes:
The game runs at high and stable FPS when Discord is closed
The issue appears to be related to background application interaction
No similar lag spikes occur in Crossout without Discord
Other games do not show the same behavior as clearly
System information (summary):
GPU: Intel Arc A770
CPU: Intel Core i7-9700K
OS: Windows 10 64-bit
Graphics API: DirectX 12
Game: Crossout (latest version)
Please let me know if you need additional information such as logs, performance captures, or Discord settings. I would appreciate any guidance or investigation into a possible compatibility or driver-related issue.
Thank you for your time and support.
