GPU Compute Software
Ask questions about Intel® Graphics Compute software technologies, such as OpenCL* GPU driver and oneAPI Level Zero
公告
519 讨论
Latest IPEX-LLM Docker WSL GPU Passthrough Issues
VladSRVZ
初学者
4,261 次查看
I'm trying to get GPU passthrough working with Docker under WSL2 Ubuntu 22.04
The platform is Raptor Lake, with 4 A770 GPUs attached. Latest WHQL drivers are installed, all GPUs confirmed functioning correctly on the Windows 11 24H2 host (also tested with 23H2).
On the WSL Ubuntu host, everything seems to be set up and functioning correctly as well... for only 1 card (Issue 1):
$ ls /dev/dxg
/dev/dxg
$ glxinfo | grep "OpenGL renderer"
OpenGL renderer string: D3D12 (Intel(R) Arc(TM) A770 Graphics)
$ clinfo | grep "Intel"
Platform Name Intel(R) OpenCL Graphics
Platform Vendor Intel(R) Corporation
Device Name Intel(R) Graphics [0x56a0]
Running the official ipex-llm image in Docker (under the WSL Ubuntu host) results in a seemingly correct device mapping, but a failure when it comes to detecting the Arc GPU as a CL device (Issue 2):
docker run -d --restart=always --net=bridge --device=/dev/dxg
--name=ipex-llm
-p 11434:11434
-v ~/.ollama/models:/root/.ollama/models
-e PATH=/llm/ollama:<OMITTED>
-e OLLAMA_HOST=0.0.0.0
-e no_proxy=localhost,127.0.0.1
-e ZES_ENABLE_SYSMAN=1
-e ENABLE_GPU=1
-e OLLAMA_INTEL_GPU=true
-e ONEAPI_DEVICE_SELECTOR=level_zero:0
-e DEVICE=Arc
--shm-size="16g"
--memory="32G"
intelanalytics/ipex-llm-inference-cpp-xpu:latest
bash -c "cd /llm/scripts/ && source ipex-llm-init --gpu --device Arc && bash start-ollama.sh && tail -f /llm/ollama/ollama.log"
Tried forwarding both /dev/dri and /dev/dxg to the same avail.
$ ls /dev/dxg
/dev/dxg
Error: unable to open display
  Platform Name  Intel(R) FPGA Emulation Platform for OpenCL(TM)
  Platform Version  OpenCL 1.2 Intel(R) FPGA SDK for OpenCL(TM), Version 20.3
  Platform Extensions function suffix  IntelFPGA
  Device Name  Intel(R) FPGA Emulation Device
  Device Name  Intel(R) Core(TM) i9-14900F
Ignoring the detection of more GPUs for now (Issue 1), why is the Arc GPU not detected by clinfo when /dev/dri and /dev/xdg seem to exist, as well as all of the required Intel software (using the official ipex-llm image)?
Any input would be greatly appreciated, been banging my head on this one for two days now!
标签 (3)
0 项奖励
0 回复数
回复
