GPU Compute Software
Ask questions about Intel® Graphics Compute software technologies, such as OpenCL* GPU driver and oneAPI Level Zero
523 Discussions
SYCL: feature test compile failed!!
evstratios
Don't delete my question.
I've been trying to get Intel Extension For PyTorch
to compile since August 2024..
Intel's script first tries to compile PyTorch for compatibility.
I can't get past PyTorch's compilation to get to compile IPEX.
I actually did get through PyTorch once but it had some error and wouldn't actually load in python.
Could you people please help me!!!
I don't understand why you only provide binaries
for your thousand dollar data center gpu cards
and you leave your enormous numbers of people
who have qualified gpus to fend for ourselves!?!!?
I am stuck. The AIs I've been using are stuck.
I need help.
I have ADL-P - I paid my money too.
Please don't give me beginner advice for idiots.
I've been at this all day every day for seven months.
I need actual help that gets me finished with this successfully.
I'm watching the AI industry pass me by because
Intel refuses to give us binaries! I'm lost. I need help.
-- Found SYCL: /opt/intel/oneapi/compiler/2025.0/include;/opt/intel/oneapi/compiler/2025.0/include/sycl;/opt/intel/oneapi/compiler/2025.0/include/sycl (found version "20250004")
compile output is:
CMake Error at third_party/torch-xpu-ops/cmake/Modules/FindSYCLToolkit.cmake:237 (message):
Can not build SYCL_CMPLR_TEST
Call Stack (most recent call first):
third_party/torch-xpu-ops/cmake/SYCL.cmake:5 (include)
third_party/torch-xpu-ops/CMakeLists.txt:38 (include)
-- Configuring incomplete, errors occurred!
Building wheel torch-2.6.0a0+git1eba9b3
-- Building version 2.6.0a0+git1eba9b3
cmake -GNinja -DBUILD_BINARY=0 -DBUILD_BY_PER_KERNEL=0 -DBUILD_CAFFE2=0 -DBUILD_CAFFE2_OPS=0 -DBUILD_PYTHON=True -DBUILD_STATS=1 -DBUILD_TEST=True -DBUILD_WITH_SANITIZER=0 -DBUILD_WITH_XPU=1 -DCMAKE_ARGS=-DCMAKE_AR=/home/evstratios/miniforge3/envs/ipex-xe/bin/x86_64-conda-linux-gnu-ar -DCMAKE_CXX_COMPILER_AR=/home/evstratios/miniforge3/envs/ipex-xe/bin/x86_64-conda-linux-gnu-gcc-ar -DCMAKE_C_COMPILER_AR=/home/evstratios/miniforge3/envs/ipex-xe/bin/x86_64-conda-linux-gnu-gcc-ar -DCMAKE_RANLIB=/home/evstratios/miniforge3/envs/ipex-xe/bin/x86_64-conda-linux-gnu-ranlib -DCMAKE_CXX_COMPILER_RANLIB=/home/evstratios/miniforge3/envs/ipex-xe/bin/x86_64-conda-linux-gnu-gcc-ranlib -DCMAKE_C_COMPILER_RANLIB=/home/evstratios/miniforge3/envs/ipex-xe/bin/x86_64-conda-linux-gnu-gcc-ranlib -DCMAKE_LINKER=/home/evstratios/miniforge3/envs/ipex-xe/bin/x86_64-conda-linux-gnu-ld -DCMAKE_STRIP=/home/evstratios/miniforge3/envs/ipex-xe/bin/x86_64-conda-linux-gnu-strip -DCMAKE_BUILD_TYPE=Release -DBUILD_PYTHON=True -DCMAKE_BUILD_TYPE=Release -DCMAKE_SYCL_DEVICE_OBJECT_OUTPUT_DIR=./sycl_objs -DCMAKE_INSTALL_PREFIX=/home/evstratios/ipex/pytorch/torch -DONEDNN_GRAPH_BUILD_COMPILER_BACKEND=1 -DSYCL_OCLOC_EXECUTABLE=/usr/bin/ocloc -DSYCL_PI_LEVEL_ZERO_DEVICE_SCOPE_EVENTS=1 -DSYCL_PI_LEVEL_ZERO_USE_IMMEDIATE_COMMANDLISTS=1 -DTORCH_XPU_ARCH_LIST=adl-p -DUSE_XPU=1 -GNinja -Wno-dev -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=/home/evstratios/ipex/pytorch/torch -DCMAKE_PREFIX_PATH=/home/evstratios/miniforge3/envs/ipex-xe/lib/python3.10/site-packages;/home/evstratios/miniforge3/envs/ipex-xe:/opt/intel/oneapi/pti/0.10/lib/cmake/pti:/opt/intel/oneapi/mkl/2025.0/lib/cmake:/opt/intel/oneapi/compiler/2025.0:/opt/intel/oneapi/vpl/2023.1.0:/opt/intel/oneapi/tbb/2022.1/env/..:/opt/intel/oneapi/pti/0.11/lib/cmake/pti:/opt/intel/oneapi/mkl/2025.1/lib/cmake:/opt/intel/oneapi/ispc/1.23/lib/cmake/ispcrt:/opt/intel/oneapi/ipp/2022.1/lib/cmake/ipp:/opt/intel/oneapi/dpl/2022.8/lib/cmake/oneDPL:/opt/intel/oneapi/dnnl/2025.1/lib/cmake:/opt/intel/oneapi/dal/2025.4:/opt/intel/oneapi/compiler/2025.1:/opt/intel/oneapi/ccl/2021.15/lib/cmake/oneCCL:/home/evstratios/miniforge3/envs/ipex-xe:/home/evstratios/miniforge3/envs/ipex-xe/x86_64-conda-linux-gnu/sysroot/usr -DGLIBCXX_USE_CXX11_ABI=1 -DJAVA_HOME=/home/evstratios/miniforge3/envs/ipex-xe/lib/jvm -DPython_EXECUTABLE=/home/evstratios/miniforge3/envs/ipex-xe/bin/python -DTORCH_BUILD_VERSION=2.6.0a0+git1eba9b3 -DTORCH_XPU_ARCH_LIST=adl-p -DUSE_ABI=1 -DUSE_AOT_DEVLIST=adl-p -DUSE_CCACHE=1 -DUSE_CHANNELS_LAST_1D=0 -DUSE_COREML_DELEGATE=1 -DUSE_CPP_CODE_COVERAGE=1 -DUSE_CUDA=0 -DUSE_CUDNN=0 -DUSE_DISTRIBUTED=0 -DUSE_EIGEN_FOR_BLAS=1 -DUSE_FAKELOWP=0 -DUSE_FBGEMM=0 -DUSE_FFMPEG=1 -DUSE_GLOO=1 -DUSE_GOLD_LINKER=1 -DUSE_IBVERB=0 -DUSE_ITT_ANNOTATION=1 -DUSE_KINETO=0 -DUSE_LEVEL_ZERO=1 -DUSE_MKLDNN=1 -DUSE_MKLDNN_ACL=0 -DUSE_MPI=0 -DUSE_NNPACK=1 -DUSE_NUMA=0 -DUSE_NUMPY=True -DUSE_ONEMKL=1 -DUSE_OPENCL=1 -DUSE_OPENCV=1 -DUSE_OPENMP=1 -DUSE_PYTORCH_QNNPACK=1 -DUSE_QNNPACK=0 -DUSE_RPC=1 -DUSE_SPLIT_FP64_LOOPS=1 -DUSE_STATIC_MKL=1 -DUSE_SYCL_ASSERT=0 -DUSE_SYSTEM_LIBS=0 -DUSE_TENSORPIPE=1 -DUSE_TORCH_XPU_OPS=0 -DUSE_UCC=0 -DUSE_VULKAN=0 -DUSE_XETLA=0 -DUSE_XNNPACK=1 -DUSE_XPU=1 /home/evstratios/ipex/pytorch
