GPU Compute Software
Ask questions about Intel® Graphics Compute software technologies, such as OpenCL* GPU driver and oneAPI Level Zero
526 Discussions
cstdint not found during dpcpp compilation
clicia
Dear all,
I have a Laptop with the following description:
Processor: 11th Generation Intel® Core™ i7-1165G7 Processor
Graphics Card: Intel® Iris® Xe MAX graphics 4GB LPDDR4x memory
Memory: 16GB, onboard, LPDDR4x, 3200MHz
Hard Drive: 1TB M.2 PCIe NVMe Solid State Drive
This laptop has two GPUs: a discrete Intel® Iris® Xe MAX graphics processor and an integrated Intel® Iris® Xe Graphics processor. I used this instruction: https://dgpu-docs.intel.com/devices/iris-xe-max-graphics/index.html to configure an Ubuntu 20.04.1 to use these cards.
Now I have a host and a device, both with 20.04.1 LTS and with oneapi installed but I am not able to run oneapi properly.
In the VM every time I try to compile using dpcpp I get an error as follows:
In the host, on the other hand, oneapi sample code seems to compile without error,  but the device code don't execute. The following image ins the output of "vector-add sample":
when I was expecting the following output:
Could anyone help me to understand what I am missing to compile and execute an dpc++ sample on my Iris GPU properly?
Thank you!!
SantoshY_Intel
Could you please let us know the version of Intel® GPU drivers you are using?
If you are not using the latest Intel® GPU drivers, then could you please try installing the Intel® GPU drivers from the link provided below and try compile and run the sample "vector-add" program?
https://dgpu-docs.intel.com/installation-guides/ubuntu/ubuntu-focal.html
Thanks & Regards,
Santosh
clicia
Hi Santosh,
In fact I was using a different version of GPU drivers. Your tutorial solved my problem and now "vector-add program" works properly:
Thank you!
SantoshY_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Santosh
