GPU Compute Software
Ask questions about Intel® Graphics Compute software technologies, such as OpenCL* GPU driver and oneAPI Level Zero
500 Discussions
heat problem with i7 14700k
adiyyyy2232
having so much heat problem with my new i7 14700k
hunter22
hunter22
i also same problem
adiyyyy2232
dose you have any solution ??
hunter22
i think using  liquid cooling might helpful
colling2.jfif
coller
adiyyyy2232
nathn34
Hey, I feel you I faced something similar when I got my i7-14700K. These chips are beasts, but they do run hot if things aren’t set up just right.
For me, the problem was mostly my cooler and airflow. What worked for me was:
1. Double-checking the cooler mount and adding a bit of high-quality thermal paste.
2. Making sure my case had proper airflow – adding one more intake fan made a noticeable difference.
3. Tweaking BIOS a little to reduce voltage, which helped temps under load.
Not sure if it helps, but while working on my builds, I realized even small changes like this can drop temps by 10–15°C.
How high are your temps under full load, and are you using an AIO or air cooler?
Moderator Edited - Removed unnecessary reference to external business.
