CS2 performance issue
maloni91
Hi, for the past few months i always have performance issue in counter strike 2.  I always have small freezes from 0.5-2 seconds , every few rounds. I am just not sure what causes a problem is it my graphic card or processor. I am using i7 14700k and Arc A750. drivers are always updated. i updated bios twice but the issue is still there (for the past 8 months). i have good power supply 32gb ddr5 ram and samsung 990 pro . I dont think PC spec are low to play this game. Does someone have similar issue and any way to fix this ?
i attached ssu report
Earl_Intel
Hi maloni91,
I'm sorry to hear that you're experiencing performance issues on your system while playing CS2. I appreciate you sharing the Intel SSU beforehand for me to check on it.
No worries, for me to further investigate on this, may I know the following details:
  • Is the game working fine before? if yes, did the issue happen after a driver or software update?
  • What digital gaming platform did you install the game?
  • What is the exact model of the monitor that you're using?
  • Are you using a HDMI or DisplayPort cable?
  • Can you also provide us the game settings that you're using while playing CS2?
Once we have this information, we will be able to proceed with the next course of action and work towards resolving the issue you are facing. Your cooperation is invaluable in helping us provide you with the best possible support.
Earl E.
maloni91
I am sorry , i was away from PC for few days.
Yes, game worked fine before (i am not sure exactly when).
I use steam to install game.
I am using HDMI on both monitors 2x Asus VA27EHE - model.
Video game settings:
Display mode : windowed
aspect: widescreen 16:9
Resolution : 1920*1080
Refresh rate: 75 Hz
Brightness: 93%
Boost Player Contrast: Enabled
V-Sync: Disabled.
Max FPS in Game - 400
Max FPS in Menus - 200
Current Video Values Present : Very High
Multisampling Anti-Aliasing Mode: 8x MSAA
Global Shadow Quality: Very High
Dynamic Shadows: All
Model / Texture Detail: High
Texture Filtering Mode: Anisotropic 16x
Shader Detail: High
Particle Detail: Very High
Ambient Occlusion: High
High Dynamic Range: Quality
FidelityFX Super Resolution: Disabled
If you need more information just let me know.
thanks in advance
Earl_Intel
Hi maloni91,
Just wondering if you had a chance to look over the questions I posted. In order for me to decide the appropriate course of action to address this issue, kindly inform me as soon as possible.
Earl E.
Earl_Intel
Hi maloni91,
Thank you for sharing this useful information.
For us to further troubleshoot the issue, try performing a clean installation of your graphics driver:
  1. Download Display Driver Uninstaller (DDU)< software and extract the file.
  2. Open DDU ****.exe and run extract program.
  3. Reboot into Windows* safe mode. (Refer to Start your PC in safe mode in Windows.)
  4. Go to the DDU extract path and double-click the Display Driver Uninstaller.exe to open DDU.
  5. Click Close in the Options window.
  6. Select device type to GPU and select device to INTEL.
  7. Click Clean and restart or Clean and Shutdown depending on your needs
  8. Wait the software to finish the process and auto reboot Windows to the normal mode or shutdown.
Download Graphics driver version: 32.0.101.6734 Intel® Arc™ & Iris® Xe Graphics - Windows*.
Earl E.
Earl_Intel
Hi maloni91,
I just wanted to check if you had the chance to review the troubleshooting steps I posted. Please let me know at your earliest convenience so that I can determine the best course of action to resolve this matter.
Earl E.
maloni91
i did steps you told me but i dont have time to check now, ill check tonight or sunday and will let you know.
thanks a lot
Earl_Intel
Hello maloni91,
Sure thing!
Let me know if there will be an improvement on your system after the troubleshooting.
Earl E.
maloni91
Hi earl,
Earl_Intel
Hello maloni91,
Thank you for sharing this update with me.
No worries, Intel is already aware of the issue and is currently investigating it.
To help us with the investigation, can you share with us the CapframeX file of your Counter-Strike 2 (CS2), preferably at least 5 to 10 minutes?
Earl E.
maloni91
HI,
here is the capframe file. i needed to zip because json upload is not supported
Earl_Intel
Hello maloni91,
Thanks for sharing the CapframeX files.
I'll further investigate internally on the provided files and share you an update on this thread after.
Earl E.
maloni91
JaveA_Intel
Hi maloni91,
We are currently investigating on the issue. We will get back to you as soon as possible. Thank you for understanding.
Jave Vincent A.
Earl_Intel
Hi maloni91,
Thank you for patiently waiting on us.
We tried to replicate the issue on our end but receive a minimal stuttering. We also tried the latest Graphics driver version 32.0.101.6790 and there are times that there are zero freezing.
For us to further troubleshoot the issue, try following these steps:
  1. Download the latest GPU driver version 32.0.101.6790, please make sure that you perform a DDU first before installing the latest version.
    1. Latest GPU version link: Intel® Arc™ & Iris® Xe Graphics - Windows*
    2. DDU link: How to Use the Display Driver Uninstaller (DDU) to Uninstall an...
  2. After updating the latest GPU drivers, try running the game again, kindly try to get a short video of the game so we can check if theres still issues.
Earl E.
Earl_Intel
Hello maloni91,
Just wondering if you had a chance to look at the troubleshooting steps I posted on the previous post.
In order to decide on the appropriate course of action to address this issue, kindly notify me as soon as possible.
Earl E.
Earl_Intel
Hi maloni91,
Earl E.
