Fortnite Crashing
Benivall246
Principiante
19.657 Vistas
Fornite keeps crashing
Hello my game sometimes started and then crash or sometimes it crash without starting.I put the game in high priority (this was very dificult to me because it send me an error when I try to do put it in high priority with the task manager)I finally put it in high priority and it continues crashing .2 months ago I was playing on 120 fps in performance mode very nice in a low resolution.I try talking with Epic games suport but they can´t solve my problem .
My pc is :
-I5-12400
-Ram 8gb and 16gb
What can i do?
0 kudos
22 Respuestas
VonM_Intel
Moderador
18.359 Vistas
Hi, Benivall246.
Thank you for sharing your issue with Fortnite crashing in our Community. To help resolve the problem, I have a few questions I'd like to ask:
  • You mentioned receiving an error when attempting to set the game to high priority using the task manager. Could you provide any specific error messages or codes that appear when the game crashes? For example, something like "DXGI_ERROR_DEVICE_REMOVED" or "Fortnite has crashed. We're very sorry this happened and we are working towards preventing it in the future." These details can help me better identify the cause of the crashes.
  • What graphics card are you using, and have you checked for the latest driver updates? Sometimes outdated drivers can contribute to crashes.
  • Could you also share what settings you are using in Fortnite, including resolution and graphics settings?
  • Have you tried running the game in windowed mode or with lower graphics settings to see if the crashes persist?
  • Is the game running on DirectX 12?
Finally, I'd like to delve deeper and verify specifics like the graphics models, precise driver versions, and any system errors. Utilizing the Intel SSU tool will enable us to collect detailed information about your system setup, which could aid in identifying the underlying cause of this issue. Also, If you have done any other tests please let me know the details so we don't cover the same ground twice.
Have a nice day!
Von M.
Benivall246
Principiante
18.347 Vistas
Hello Vonm
- Okey the error that appear is this Fortnite has crashed. We're very sorry this happened and we are working towards preventing it in the future
-I am not using graphic card I play with intedrated intel graphic of the proccesos I5 12400,now i will try to update the drivers
-My setting are:
   -120 fps limit
   -Fullscreen
  -Resolution  16:9 1280x720
  -Mode performance
  -50 3d resoltion
  -And al in low (mesh,textures and viewing distance)
-Windowed mode I dont try or use this because it make my lose a lot of fps i only play fullscreen
-I play in performance mode not in DirectX 11 or 12
Benivall246
Principiante
18.323 Vistas
VonM_Intel
Moderador
18.316 Vistas
Hello, Benivall246.
Thank you for sharing the details with us. Let’s work together to troubleshoot the issue. I recommend the following steps to fix the error.
  • Get the latest Windows* update:
    1. Open the Windows Start Menu (button with the Windows logo).
    2. Click Settings (button with the gear symbol).
    3. Click Update & Security.
    4. Select Install Now or Check for Updates.
    5. Wait for the update to be installed.
    6. Click Restart now after the update is installed.
  • Perform Graphics Driver Clean Installation:
    1. Download and install the latest Intel® Graphics driver.
    1. Follow the Execute a Clean Installation During Driver Installation steps from the article: Clean Installation of Intel® Graphics Drivers in Windows*
Furthermore, I recommend changing the Fortnite Window Mode outside the game. Changing the Window Mode or Resolution while in-game may cause crashing issues as the game is rendered under a specific resolution.
Von M.
Benivall246
Principiante
18.256 Vistas
Hello I installed the lasted drivers and the lasted windows update  but it continues crashing
VonM_Intel
Moderador
18.222 Vistas
Hello, Benivall246.
Thank you for informing me. I'm sorry to hear that the issue persists even after installing the latest drivers and Windows update. In the meantime, I'll need to conduct additional research on this issue and will post an update in this thread once I have more information.
Von M.
Reinhardt
Principiante
18.039 Vistas
Sorry to bother, but I'd like to add on and say that this has been a recurring issue concering Fortnite since November of last year and there is yet no solution to this problem whatsoever and even if a person loads into a match the game stutters crazy whilst moving around whether or not you are running or walking and usually ends either with the person dying or the game ultimately crashing. What's worse about this is that even going from different pages like the lobby screen to the battle pass ends for me with a crash, which did not happen before.
Benivall246
Principiante
17.919 Vistas
Yeah my bro I think it has no solution ,I have ever tried everything but it alwayls the same result ,crashing the game.I will wait for fornite update that fix that
VonM_Intel
Moderador
17.899 Vistas
Hello, Benivall246.
Just an update. I wanted to inform you that work is still in progress to address the Fortnite crashes you’ve encountered. In the meantime, I kindly ask that you keep your graphics driver up to date to ensure optimal performance.
@Reinhardt ,
I empathize with your situation and the issue you are facing. However, I kindly request that you create a new thread for your case. This will allow us to focus on your specific problem and provide you with better assistance.
Von M.
VonM_Intel
Moderador
17.749 Vistas
Hello, Benivall246.
I appreciate your patience in this matter. I would like to gather the following information:
You may follow the DX logs instruction attached in this thread.
Von M.
VonM_Intel
Moderador
17.661 Vistas
Hello, Benivall246.
Von M.
Benivall246
Principiante
17.634 Vistas
Hello ,sorry I wasn´t at home .There are the files , I hope that this files help you to find the solution
I can´t submit all the files because they are heavy but i created a drive here is
https://drive.google.com/drive/folders/19Tnb06Q3uAKh4v0y5LZuesZJ4IJCkLVs?usp=drive_link
There is all the files that you asked me,another thing is that next month i wil buy a rx 7600 8gb that I think that will help with the crashes
Thank u for the assistance!!
VonM_Intel
Moderador
17.612 Vistas
Hello, Benivall246.
No worries, and thank you for sharing the files. I appreciate the effort in uploading them to Google Drive. I'll review the data and get back to you with any findings or next steps as soon as possible. Thanks again for your patience and cooperation.
Von M.
VonM_Intel
Moderador
17.553 Vistas
Hello, Benivall246.
I appreciate your patience in this matter. Based on my investigation, please be guided that we have an updated graphics driver version from our site. I recommend installing the latest graphics driver version 32.0.101.6651 to see if it resolves the issue. Let us know if the problem persists. If you need further assistance, feel free to reach out.
Looking forward to your update.
Von M.
Benivall246
Principiante
17.510 Vistas
Sorry ,but it didn´t work .I installed and restar the pc but it continues crashing,what about that I am going to buy a rx 7600 8gb it will help??
VonM_Intel
Moderador
17.250 Vistas
Hello, Benivall246.
Thank you for trying the installation and restarting your system. Regarding your question about upgrading to an RX 7600 8GB GPU, while it may improve overall system performance, it might not fully resolve the crashing issue if the problem is unrelated to the graphics card. Since the crashes persist, I will need to conduct a more in-depth investigation to identify the root cause. I will provide an update in this thread as soon as I have more information.
Von M.
VonM_Intel
Moderador
17.158 Vistas
Hello, Benivall246.
Thank you for your patience. I have sent you an email regarding this matter. Please check your inbox, and if you don’t see it, kindly review your SPAM folder as well.
Von M.
VonM_Intel
Moderador
17.099 Vistas
Hello, Benivall246.
I have received your email regarding this matter. Additionally, I have sent you another email about it. Please check your inbox, and if you don’t find it there, kindly check your SPAM folder as well.
Von M.
Darklegion1978
Nuevo Colaborador I
16.978 Vistas
@VonM_Intel
Is there any Update for the Issue.
Fortnite with Performance Mode crashes at me since last year and nothing helped.
Driver is up to Date, Windows too, tried also different Ram.
Nothing helps.
Its randomly with crashing, and i get the same error message as the Thread starter.
It also doesnt matter how many FPS in Game, unlimited, or fixed.
Thanks and Greetings
Roman
SamTheSam1002
Principiante
16.732 Vistas
I face the same issue, I emailed intel's support, and their only "helpful" response was to wait for an update, I waited for the driver update andddd, Nothing. the issue was not fixed.
I can give a copy paste / screen shot of what event viewer says if that'll be helpful for support.
Responder
