661 Discussions
Intel Graphic Driver missing something for Vulkan in X-Plane 11 and it may cause to fault rendering
Gingy
Following my screenshot after using Vulkan rendering option in X-Plane 11 and game Log show me the error even I have installed lastest driver version (My Screenshot and system info are below)
WARNING: extension missing proc glGetnTexImage. This is a problem with your video driver.
WARNING: extension missing proc glGetnUniformdv. This is a problem with your video driver.
WARNING: extension missing proc glGetnMapdv. This is a problem with your video driver.
WARNING: extension missing proc glGetnMapfv. This is a problem with your video driver.
WARNING: extension missing proc glGetnMapiv. This is a problem with your video driver.
WARNING: extension missing proc glGetnPixelMapfv. This is a problem with your video driver.
WARNING: extension missing proc glGetnPixelMapuiv. This is a problem with your video driver.
WARNING: extension missing proc glGetnPixelMapusv. This is a problem with your video driver.
WARNING: extension missing proc glGetnPolygonStipple. This is a problem with your video driver.
WARNING: extension missing proc glGetnColorTable. This is a problem with your video driver.
WARNING: extension missing proc glGetnConvolutionFilter. This is a problem with your video driver.
WARNING: extension missing proc glGetnSeparableFilter. This is a problem with your video driver.
WARNING: extension missing proc glGetnHistogram. This is a problem with your video driver.
WARNING: extension missing proc glGetnMinmax. This is a problem with your video driver.
Vulkan Layers : VK_LAYER_VALVE_steam_overlay (1), VK_LAYER_VALVE_steam_fossilize (1)
Vulkan Device : Intel(R) HD Graphics 620 (da2000000)
Vulkan Version : 1.3.215
Vulkan Driver : 0.404.2121
Vulkan Extensions : VK_EXT_full_screen_exclusive VK_KHR_swapchain VK_KHR_external_memory VK_KHR_external_memory_win32 VK_EXT_external_memory_host VK_KHR_external_semaphore VK_KHR_external_semaphore_win32 VK_KHR_external_fence VK_KHR_external_fence_win32 VK_KHR_timeline_semaphore VK_KHR_win32_keyed_mutex VK_KHR_get_memory_requirements2 VK_KHR_bind_memory2 VK_KHR_dedicated_allocation VK_KHR_sampler_mirror_clamp_to_edge VK_KHR_maintenance1 VK_KHR_maintenance2 VK_KHR_maintenance3 VK_KHR_maintenance4 VK_KHR_synchronization2 VK_KHR_shader_draw_parameters VK_KHR_push_descriptor VK_KHR_descriptor_update_template VK_KHR_multiview VK_KHR_shader_float16_int8 VK_KHR_shader_float_controls VK_KHR_16bit_storage VK_KHR_8bit_storage VK_EXT_shader_subgroup_ballot VK_EXT_shader_subgroup_vote VK_KHR_storage_buffer_storage_class VK_KHR_variable_pointers VK_KHR_relaxed_block_layout VK_EXT_sampler_filter_minmax VK_KHR_device_group VK_EXT_ycbcr_2plane_444_formats VK_EXT_4444_formats VK_EXT_post_depth_coverage VK_EXT_shader_viewport_index_layer VK_EXT_shader_stencil_export VK_EXT_conservative_rasterization VK_EXT_sample_locations VK_KHR_draw_indirect_count VK_EXT_multi_draw VK_KHR_image_format_list VK_EXT_vertex_attribute_divisor VK_EXT_descriptor_indexing VK_EXT_inline_uniform_block VK_KHR_create_renderpass2 VK_KHR_dynamic_rendering VK_KHR_swapchain_mutable_format VK_KHR_depth_stencil_resolve VK_KHR_driver_properties VK_KHR_vulkan_memory_model VK_EXT_conditional_rendering VK_EXT_hdr_metadata VK_EXT_depth_clip_enable VK_EXT_depth_clip_control VK_EXT_scalar_block_layout VK_KHR_imageless_framebuffer VK_KHR_buffer_device_address VK_EXT_buffer_device_address VK_EXT_host_query_reset VK_KHR_performance_query VK_NV_device_diagnostic_checkpoints VK_KHR_separate_depth_stencil_layouts VK_KHR_shader_clock VK_KHR_spirv_1_4 VK_KHR_uniform_buffer_standard_layout VK_EXT_separate_stencil_usage VK_EXT_fragment_shader_interlock VK_EXT_index_type_uint8 VK_EXT_primitive_topology_list_restart VK_KHR_shader_subgroup_extended_types VK_EXT_line_rasterization VK_EXT_memory_budget VK_EXT_memory_priority VK_EXT_texel_buffer_alignment VK_INTEL_performance_query VK_EXT_subgroup_size_control VK_EXT_shader_demote_to_helper_invocation VK_EXT_pipeline_creation_feedback VK_EXT_pipeline_creation_cache_control VK_KHR_pipeline_executable_properties VK_EXT_transform_feedback VK_EXT_provoking_vertex VK_EXT_extended_dynamic_state VK_EXT_extended_dynamic_state2 VK_EXT_vertex_input_dynamic_state VK_EXT_custom_border_color VK_EXT_robustness2 VK_EXT_image_robustness VK_EXT_calibrated_timestamps VK_KHR_shader_integer_dot_product VK_KHR_shader_subgroup_uniform_control_flow VK_KHR_shader_terminate_invocation VK_KHR_workgroup_memory_explicit_layout VK_EXT_shader_atomic_float VK_KHR_copy_commands2 VK_KHR_shader_non_semantic_info VK_KHR_zero_initialize_workgroup_memory VK_EXT_shader_atomic_float2 VK_EXT_global_priority VK_EXT_global_priority_query VK_KHR_global_priority VK_KHR_format_feature_flags2 VK_EXT_color_write_enable VK_EXT_private_data VK_EXT_image_2d_view_of_3d
Vulkan Instance Extensions: VK_KHR_surface VK_KHR_win32_surface VK_KHR_external_memory_capabilities VK_KHR_external_semaphore_capabilities VK_KHR_external_fence_capabilities VK_KHR_get_physical_device_properties2 VK_KHR_get_surface_capabilities2 VK_KHR_device_group_creation VK_EXT_swapchain_colorspace VK_EXT_debug_report VK_EXT_debug_utils
Andres_Intel
Hello Gingy,
Thank you for posting on the Intel communities. I am sorry to hear that you are having graphic corruption issues with your Intel® HD Graphics 620, I will be happy to help you.
I want to let you know that Intel is currently investigating this issue, under bug ID #18015534950.
Let me know if you have further questions.
Andres P.
Andres_Intel
Hello Gingy,
Andres P.
Andres_Intel
Hello Gingy,
Andres P.
sonofjon
I have the same problem. Here is the list of missing extensions that are logged when I try to install x-plane version 12.
No UBOs if GLSL < 1.5 or buf storage isn't supported.
Vulkan Layers :
0:00:00.000 W/GFX/VK: Unknown device vendor ID 8086, for device Intel(R) UHD Graphics 620 (skipping)
I installed a newer date version of the Intel UHD Graphics 620 driver version 31.0.101.2125 dated 5/23/2023.  Also, I am running on Windows 11
