758 Discusiones
Resident Evil 9 Requiem - "Unsupported Graphics" Error on Intel Iris Xe (i7-1355U)
Bhagirathsinh19
5.282 Vistas
Hello Intel Support Team,
I am using the following configuration:
Processor: Intel Core i7-1355U
Graphics: Intel Iris Xe Graphics
RAM: 16GB (Dual Channel)
Operating System: Windows 11 (Fully Updated)
Graphics Driver: Latest Intel generic driver installed
When I try to launch Resident Evil 9 Requiem, the game does not start and displays the error message:
“Unsupported Graphics”
The official minimum requirement mentions GTX 1660. However, some older integrated GPUs like AMD Vega 11 are reportedly able to launch the game at low settings.I would appreciate technical clarification on whether this is a hardware limitation or a driver-level compatibility issue.
Thank you for your support.
11 Respuestas
Dadiegamer78
Novato
5.272 Vistas
even an ryzen 3200 with igpu can run this why is iris xe not able to run it
HeroS_Intel
Moderador
5.236 Vistas
Hi Bhagirathsinh19,
Thank you for reaching out to the Intel Community Forum. Since this is an OEM (Branded Laptop) original equipment manufacturer device, please take into consideration that our support may be limited since we are not familiar with the technology, settings, customizations, custom drivers, and features that the OEM has designed and installed your system, nevertheless, I will do my best to assist you. To assist us in investigating the issue, please provide the following details:
  • What is the exact model of your laptop?
  • Have you tried using the OEM driver for testing?
  • What are the troubleshooting steps that you tried so far?
  • Have you used Display Driver Uninstaller (DDU) to completely remove all residual drivers and installed a new one?
  • Which gaming platform did you use to download the game?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility. Kindly also untick the networking category before scanning.
Hero Yuki S.
Bhagirathsinh19
4.516 Vistas
I tried all Driver Versions but didn't work.Intel specially provided driver version for arc family dedicated to resident evil requiem at 25th february but didn'n give any update of iris xe integreted gpu.some older gpu like gt1030 and igpu like vega8 is also able to launch it but not iris xe.We wanted to inform you to provide driver for resident evil requiem as soon as possible.
Thank.
HeroS_Intel
Moderador
4.873 Vistas
Hi Bhagirathsinh19,
I wanted to check if you had the chance to review the questions I posted. Please let me know at your earliest convenience so that we can determine the best course of action to for this matter.
Hero Yuki S.
Bhagirathsinh19
4.516 Vistas
Radnezvod
Principiante
4.481 Vistas
Iris Xe has been left as legacy support, they won't release anything unless it's for Intel Arc. We should expect Capcom to do something but I highly doubt it will happen anytime soon.
HeroS_Intel
Moderador
4.297 Vistas
Hi Bhagirathsinh19,
Based on our assessment, the game is outside the system requirements set by the developer. It would be best to consult with the game developer if they will be adding support for the reported iGPU.
Hero Yuki S.
Marius02kr
Principiante
3.231 Vistas
So we need to wait the game developer in order to add support for intel graphics?. The previous game capcom released (RE4 remake/ 2023) goes very well on my pc without problem (intel graphics). I buy this new requiem and I see the error unsupported graphic card. Why these types of errors occurs?
Alessandro2026
Principiante
2.393 Vistas
Good evening, I just installed Resident Evil 9 Requiem on my PC. Unfortunately, when I try to launch it, I get the following error message: I've attached a screenshot. What can I do? I have Windows 11 and I just updated the graphics card driver, but it still doesn't work. Can someone please help me fix this? Thank you very much.2026-03-30.png
AlHill
Superusuario
2.392 Vistas
@Alessandro2026   It says the Intel UHD graphics is not supported.
And, did you check the requirements of the game?
So the Intel customer support technicians can have more information about your system, download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[CoPilot is a virus, W11 is a keystroke logger, all from MicroSlop]
Nikesh001
Principiante
281 Vistas
having the same problem, hope this gets fixed.
Responder
