23587 Discussions
10 bit grayscale mobile Intel Iris Xe Graphics
condylus
I'm a radiologist, I'm thinking of buying a new laptop. I wanted to use it not only for office and internet applications, but also for reading radiology exams. I'm planning to connect laptop to diagnostic medical display (perhaps Barco MDCC 4430 or EIZO RX 660) via displayport. There are many laptops available with 11th gen Intel processors and Intel Iris Xe Graphics, many of them have type C USB ports (with displayport or thunderbolt).
I'm wondering if a laptop with Intel Iris Xe Graphics connected to a medical display via USB-C - displayport cable will allow viewing 10 bit grayscale DICOM images (which is the format used for radiology exams)?
Thanks in advance,
condylus
AndrewG_Intel
Hello condylus
Please allow us to investigate further regarding this question and we will be posting back in the thread as soon as more details are available.
Andrew G.
condylus
AndrewG_Intel
Hello condylus
Thank you for your patience in this matter.
In regards to this request, you should need to confirm the compatibility with the display manufacturers (OEM) and also make sure that the apps/tools you will be using are compatible with the Intel® Graphics Processing Unit (GPU).
We have seen some scenarios of customers using programs that open DICOM images. However, the best thing to do is to confirm directly with the OEMs and the software developers for the proper compatibility information and guidance.
Andrew G.
AndrewG_Intel
Hello condylus
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
