23091 Discussions
15.36.21 CONTROL PANEL CRASH WHEN NO DISPLAY IS CONNECTED !!!
ksoni1
i'm using my Intel 4770 System (HD 4600) for Server with no Monitor or other Display connected.
When i try to open DISPLAY Settings from Control Panel the whole CP of 15.36.21 Drivers is crashing !!!!
Even in a new Installation of Windows it happens
So i uninstalled 15.36.21 and go one Driver Version back and the Display Settings are opening normally and i am able to add custom Displays with custom Refresh Rates (need that for special purposes).
Hope this bug will be gone in the next Beta/Release Drivers.
Greetings
Jose_H_Intel1
So, the issue happens with version 4222 but not with 4170?
What operating system and remote access software are you using?
ksoni1
New Installation Windows 8.1 and Windows 7 x64 ...
15.36.21 CP is always crashing when no Display is connected.
Any Driver Version before is working fine.
So its obvious bug of 15.36.21 Drivers
Jose_H_Intel1
These are some possible workarounds:
ksoni1
No need to workaround... just installed any Version before 15.36.21 and the DISPLAY Menu is working fine!
Hopefully will be fixed with the next Release
Greetings
Jose_H_Intel1
What remote access software are you using?
ksoni1
Jose_H_Intel1
Please provide us with more information from your system:
ksoni1
I have attached the dxdiag Log and the CP Log as you requested.
Hope it will help you to find the bug !
In the meanwhile i switch back to 15.36.19 again and wait for your fix ...
ksoni1
Installed today new 15.36.22 Drivers ... same crashing of "DISPLAY" menu again 😞
Bryce__Intel
Hi keysonic2,
I'm picking up this issue to have the debug team investigate. Would you be willing to provide the information they request in the link below? I see your CP and DXDiag already provided above, no need to provide this again unless something in your config has changed. Appreciate the assistance.
ksoni1
Installed the Latest 15.36.23 Intel HD 4600 Drivers and its still crashing when no Monitor is connected.
Did you find already the error ?
THE LAST WORKING DRIVER WITHOUT CRASHING AT DISPLAY MENU: "15.36.19.4170"
Bryce__Intel
Hi keysonic2
Would you be willing to provide the information our investigation team requests in the link below? Your concern will not be reviewed until this information is provided. I see your CP and DXDiag already provided above, no need to provide this again unless something in your config has changed. Appreciate the assistance.
/thread/77761 Default level information for reporting Graphics issues
ksoni1
PROBLEM FIXED in Latest 10.18.14.4264 (15.36.24) from Windows Update.
CP Display Menu no crash anymore
THANK YOU !
