Hi Guys,
Trying to figure out how to make the Intel G965 compatible with a monitor resolution of 1600x900. It seems not to be supported by the card ( Using a Dell XPS 210 PC). I looked at http://www.jjclements.co.uk/index.php/2007/07/19/intel-gfx-driver-resolution-fix http://www.jjclements.co.uk/index.php/2007/07/19/intel-gfx-driver-resolution-fix and I cant find a DTD / code to input into the igxp32.inf file for this resolution. Any ideas on how to fix this incompatibility issue or does anyone know the code? Strangely when I use the Intel Graphics Media Accelerator Driver Application for setting the 1600x900 resolution it works but this resolution is lost on PC restart so I have to set it each time the PC starts. I'm using a Dell IN2010N Monitor that auto adjusts to a 1400 resolution due to the incompatibility on each start up.
Below is the igxp32.inf file content:
; Copyright (c) Intel Corporation (2008).
; INTEL MAKES NO WARRANTY OF ANY KIND REGARDING THE CODE. THIS CODE IS
; LICENSED ON AN "AS IS" BASIS AND INTEL WILL NOT PROVIDE ANY SUPPORT,
; ASSISTANCE, INSTALLATION, TRAINING OR OTHER SERVICES. INTEL DOES NOT
; PROVIDE ANY UPDATES, ENHANCEMENTS OR EXTENSIONS. INTEL SPECIFICALLY
; DISCLAIMS ANY WARRANTY OF MERCHANTABILITY, NONINFRINGEMENT, FITNESS FOR ANY
; PARTICULAR PURPOSE, OR ANY OTHER WARRANTY. Intel disclaims all liability,
; including liability for infringement of any proprietary rights, relating to
; use of the code. No license, express or implied, by estoppel or otherwise,
; to any intellectual property rights is granted herein.
; Installation inf for the Intel Corporation graphics adapter.
[Version]
Signature="$WINDOWS NT$"
Provider=%Intel%
ClassGUID={4D36E968-E325-11CE-BFC1-08002BE10318}
Class=Display
CatalogFile=igfxnt5.cat
DriverVer=12/12/2008,6.14.10.5016
[DestinationDirs]
DefaultDestDir = 11 ; system32
ialm.Miniport = 12 ; drivers
ialm.Display = 11 ; system32
Copp.Copy = 11 ; system32
MedKrnG400.Copy = 11 ; system32
MedKrnG500.Copy = 11 ; system32
CUI.Copy = 11 ; system32
OpenGL.Copy.Legacy = 11 ; OpenGL Drivers in System32
OpenGL.Copy.Gen4 = 11 ; OpenGL Drivers in System32
; Driver information
[Manufacturer]
%Intel% = Intel.Mfg
[Intel.Mfg]
%iBWGX0% = i965G0, PCI\VEN_8086&DEV_2982
%iBWGX1% = i965G1, PCI\VEN_8086&DEV_2983
%iBWGQ0% = i965G0, PCI\VEN_8086&DEV_2992
%iBWGQ1% = i965G1, PCI\VEN_8086&DEV_2993
%iBWGC0% = i965G0, PCI\VEN_8086&DEV_29A2
%iBWGC1% = i965G1, PCI\VEN_8086&DEV_29A3
%iBWGZ0% = i965G0, PCI\VEN_8086&DEV_2972
%iBWGZ1% = i965G1, PCI\VEN_8086&DEV_2973
%iCRGD0% = i965GM0, PCI\VEN_8086&DEV_2A02
%iCRGD1% = i965GM1, PCI\VEN_8086&DEV_2A03
%iCRGE0% = i965GM0, PCI\VEN_8086&DEV_2A12
%iCRGE1% = i965GM0, PCI\VEN_8086&DEV_2A13
%iBLBG0% = iBLB0, PCI\VEN_8086&DEV_29C2
%iBLBG1% = iBLB1, PCI\VEN_8086&DEV_29C3
%iBLBQ0% = iBLB0, PCI\VEN_8086&DEV_29B2
%iBLBQ1% = iBLB1, PCI\VEN_8086&DEV_29B3
%iBLBQC0% = iBLB0, PCI\VEN_8086&DEV_29D2
%iBLBQC1% = iBLB1, PCI\VEN_8086&DEV_29D3
%iCNTG0% = iCNT0, PCI\VEN_8086&DEV_2A42
%iCNTG1% = iCNT1, PCI\VEN_8086&DEV_2A43
%iEGLG0% = iEGL0, PCI\VEN_8086&DEV_2E02
%iEGLG1% = iEGL1, PCI\VEN_8086&DEV_2E03
%iEGLQ4G0% = iEGL0, PCI\VEN_8086&DEV_2E12
%iEGLQ4G1% = iEGL1, PCI\VEN_8086&DEV_2E13
%iEGLG4G0% = iEGL0, PCI\VEN_8086&DEV_2E22
%iEGLG4G1% = iEGL1, PCI\VEN_8086&DEV_2E23
%iEGLGVG0% = iEGL0, PCI\VEN_8086&DEV_2E32
%iEGLGVG1% = iEGL1, PCI\VEN_8086&DEV_2E33
; General installation section
[i965G0]
DelFiles=CUI.DelFiles
CopyFiles=ialm.Miniport, ialm.Display, Copp.Copy, MedKrnG400.Copy, CUI.Copy,Resource.Copy,CUISDK.Copy , OpenGL.Copy.Gen4
AddReg = CUI.AddReg , OpenGL.AddReg.Gen4, Sprite.AddReg, CUISDK.AddReg
DelReg = CUI.DelReg , CUISDK.DelReg
;InstallINF = 0
[i965G1]
;InstallINF = 0
[i965GM0]
;InstallINF = 0
[i965GM1]
;InstallINF = 0
[iBLB0]
CopyFiles=ialm.Miniport, ialm.Display, Copp.Copy, CUI.Copy,Resource.Copy,CUISDK.Copy , OpenGL.Copy.Legacy
AddReg = CUI.AddReg , OpenGL.AddReg.Legacy, CUISDK.AddReg
;InstallINF = 0
[iBLB1]
XXXWHITESPA...
specific section of file:
[NonEDIDMode_AddSwSettings]
HKR,, TotalDTDCount, %REG_DWORD%, 5 ; This shows number of DTDs to be used. ; 0-->Disable the feature.
;Following keys have 20 bytes (18 byte DTD + 2 Byte flags).
HKR,, DTD_1,%REG_BINARY%, 01,1D,80,18,71,1C,16,20,58,2C,1A,00,00,00,00,00,00,86,37,01 ;[email protected]
HKR,, DTD_2, %REG_BINARY%, 01,1D,80,D0,72,1C,16,20,10,2C,1A,80,00,00,00,00,00,86,37, 01 ;[email protected]
HKR,, DTD_3,%REG_BINARY%, 01,1D,00,BC,52,D0,1E,20,B8,28,25,40,00,00,00,00,00,04,37, 01 ;[email protected]
HKR,, DTD_4, %REG_BINARY%, 01,1D,00,72,51,D0,1E,20,6E,28,25,00,00,00,00,00,00,06,37,01 ;[email protected]
HKR,, DTD_5,%REG_BINARY%, 00, 00, 00 ,00, 00, 00,00, 00, 00,00, 00, 00,00, 00, 00,00, 00, 00,00, 00 ;Fifth DTD
I need to change:
TO SOMETHING LIKE
What should the numbers in green be?
