23688 Discussions
1909 new intel controller panel missing a feature
BBen01
HDMI connect to the monitor, the color don't display well. that is the new controller pannel lost a feature. china name is '量化范围', i don't know English mean 'Quantization range', default is 'Limited range', i need to change to 'full range'
Wanner_G_Intel
Hello BBen01,
Thank you for submitting your question on this Intel® Community.
To try to find the root cause of this issue, we would like to have more information about your system configuration (e.g. driver versions, system model, graphics controller, etc.)
Please generate the following reports:
  • DxDiag*
  1. Go to Start > Run or Windows Key + R.
  2. On the Run prompt, type "dxdiag" then click OK.
  3. On the DirectX Diagnostic Tool window, click on Save All Information.
  4. Browse to a folder, type in a filename then click Save.
  • Intel® System Support Utility (Intel® SSU) report.
  1. Intel® SSU Download link
  2. Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  3. Click on the menu where it says "Summary" to change to "Detailed View".
  4. To save your scan, click on "Next", then "Save".
  • Are you using adapters to connect external monitors to a computer?
Wanner G.
A Contingent Worker at Intel
Wanner_G_Intel
Hello BBen01,
If you need further assistance, please let us know. We will be glad to assist you.
Wanner G.
Wanner_G_Intel
Hello BBen01,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Wanner G.
