23048 Discussions
285K integrated graphics - artifacts when memory speed above 7200
Strebor
ASRock Z890 Steel Legend WiFi (BIOS 2.11.AS01)
285K
G.Skill F5-8000J4048F24G x2
990 Pro
Seasonic Prime Titanium 750W
Windows 10 64-bit
Running this system with only the integrated GPU on the 285K at the moment. Memory is rated to run at 8000. However, when I set any value above 7200 (via XMP profile, including voltage adjustment to 1.35, and auto-timings) then I get small graphical artifacts across the display after booting into Windows. The artifacts increase in frequency the more programs are running or with a heavy load on the system.
When I set the memory to 7200 or below then the artifacts are completely gone, and system is completely stable.
Troubleshooting I've tried so far:
Removing RAM sticks and trying 1 at a time in slot 4, same result as when slot 2 and 4 are populated together. Both individually display artifacts above 7200, and both stop displaying artifacts when clocked down to 7200.
Tried various minor voltage increases to other CPU sub-systems, no effect.
Heavily loaded the system at memory speed 7200, completed several memory tests with no issue.
Tried with all CPU settings at stock, same results.
Tried with CPU ring bus at 4000, same results.
Tried Gear 2 and Gear 4, same results.
Tried a second HDMI cable, same results.
Apricate any guidance.
Thank you,
Glenn
Strebor
Had been using a B580 without issues, tried today disconnecting that card and running only the integrated again. Issue does appear to be resolved with past few months of driver updates.
JeanetteC_Intel
Hello Strebor,
I'll check on this and will post an update once it's available.
JeanetteC.
timedev
I have exactly the same problem, and I don't think this is something that happens randomly.
My platform is Intel 285k + Gigabyte Aorus Z890 + 24GBx2 Dual Hynix M-die 8000 RAM. When I use the XMP default of 8000MHz, I get very small artifacts on the screen, which increase as the load increases. When I reduce the memory to 6800MHz, there are no issues.
Additionally, when I connect my discrete GPU, a Gigabyte 4080s, and use it to drive the monitor, there are no issues. However, when decoding or playing videos, the system uses the low-power Intel 285k integrated GPU (iGPU) for decoding. In these cases, I randomly get green screen artifacts, and the iGPU load suddenly spikes to 100%. But this doesn’t happen every time; usually, playback works fine.
To summarize:
  1. When using a discrete GPU (DP cable to monitor) and using the iGPU for decoding while gaming with the discrete GPU, the iGPU unexpectedly spikes to 100%, leading to occasional green screen artifacts, but the system UI remains fine.
  2. When using the discrete GPU (only for gaming) and connecting the display via Thunderbolt, small white artifacts randomly appear on the desktop, especially when moving windows. These artifacts increase with load, but lowering the memory frequency to 6800MHz resolves the issue.
Please help solve this, or else the experience with the 285k is really poor.
timedev
btw, I’m an overclocking expert, and I’ve tried all possible methods, including increasing iGPU voltage and memory voltage, to resolve this issue, but unfortunately, none of them helped.
JeanetteC_Intel
Hello Strebor,
Good day!
Try the following suggestions:
  1. Start Control Panel, click Hardware and Sound, and then click Device Manager.
  2. Expand Display Adapter, right-click the Intel Graphics entry, and click Uninstall.
  3. On the Confirm Device Removal dialog box, click Delete the driver software for this device to delete the Intel HD Graphics driver, then click OK to start the uninstall process.
  4. When the uninstall process is complete, disconnect your computer from the internet and make sure it will not auto-connect on reboot. Restart your system.
  5. Unzip the file (OEM driver file) to a designated location or folder.
  6. Open Device Manager
  7. Expand the Display adapters section.
  8. Right-click the Intel® graphics entry and select Update Driver Software. Note: The graphics entry may be "Microsoft Basic Display Adapter". *Please check if the artifacts occur using the Microsoft Basic Adapter as well.
  9. Click Browse my computer for driver software.
  10. Click Browse and select the directory where the driver files are found.
  11. Click Next. Drivers are now being installed.
  12. Reboot your computer when prompted.
Alternatively, you can use Intel® Driver and Support Assistant to download and install the HD Graphics driver.
  • Perform a system restore to a point when the artifacts were not present. Steps to perform a System Restore in Windows® 10:
  1. In the Search option located in the start menu type Restore
  2. Select Create a Restore Point from the search results.
  3. Click System Restore.
  4. Click Next after the initial Wizard screen.
  5. Select either Recommended restore point or Choose a different restore point if you have manually made previous backups.
  6. Select a restore point from the list of available options.
  7. Click Next to finish.
Reference article:
Experiencing Artifacts with Intel® Graphics
Let me know how it goes.
Jeanette C.
JeanetteC_Intel
Hello Strebor,
Let us know if you have any questions.
JeanetteC.
JeanetteC_Intel
Hello Strebor,
As I have not heard from you for the past few days, I will proceed in closing this thread. Should you need assistance in the future, please submit a new question as this thread will no longer be monitored.
Sincerely,
JeanetteC.
cowbawx
i'm having the same issue, your instructions did not help at all.
cowbawx
@JeanetteC_Intel  can you reply to this please? this is very annoying...
NA-
I am experiencing the same issue (artifacts above 6600Mhz) as everyone above while using AstroPad's Luna Display USB-C adapter. I never experienced this issue with previous gen intel CPUs(12-13 series & Intel Xeon W Cpus). There is no over heating issues chip idols at 35c and reaches 85c on all core load. The thunderbolt usb-c connection need for operation is not over saturated and is operational.
System Specs:
CPU: Intel core 9 285k (Intel Arc Graphic Driver 32.0.101.6458, Intel Graphic Software Version 24.50.1001.1 )
MOBO: MSI MPG Z890i TI WIFI (Bios: 7E33v1A4 - 2025.01.16)
RAM: 96GB (2x48GB) Corsair Vegeance DDR5 CL32 @ 6600MHz
GFX: Nvidia Geforce 4090FE (Studio Drivers 566.36 - 2024.12.10)
OS:  Windows 11 Pro, Version 10.0.22631
Sviox
I also see some minor but frequent artifacts with any of the three XMP configurations available on Kingston Fury CUDIMM RAM set when running any 3D content or GPU accelerated video on my 265K. The artifacts are immediately visible when launching affected media (i.e. not a heat issue) and only take place within such content bounds, not universally on the screen. Stress test applications indicate the system to be stable.
Arb2
I was experiencing the same issue with my 285k on an ASUS motherboard. Sporadic artifacts on the screen, especially when multiple windows were open in Windows.
I updated the Intel ME firmware from ASUS' website. The latest version as of 02-27-25 was 1854.
This seems to have fixed the problem for me. I can run a dozen YouTube videos simultaneously without any issues.
 I have not done a thorough tests using hardware test software but the IME firmware update seems to have fixed it in my case.
Arabo
Sviox
Unfortunately, I am already using the same version 19.0.0.1854 of CSME. Retried with the latest graphics driver but no luck. I can also confirm that, especially with some load, a few artifacts can be seen on desktop as well.
I guess I'll have to wait and see what happens when a dedicated GPU is used.
Stefano3
Hi team, recently bought a intel core ultra 9 285k and I'm experiencing weird artfact during video playing (i.e. you tube and other)...
I see some green dot / imperfection for a part of the video. I'm using the integrated GPU.
I solved just underspeeding my ddr5 from the original 6800mhz to 6400mhz (even at 6600 mhz same issue) and now video plays well.
My build:
- Gigabyte AOURUS Elite wifi 7 z890
- Intel core ultra 9 285k
- Corsair CMK64GX5M2X6800C32 2x32 MB
- Corsair HX1000w
- Samsung MP700pro 2Tb
Temp 25-30 during playback.
Firmware gigabyte F15, Driver video intel  32.0.101.6556
In there anything I can try to recover my 6800 mhz?
PharmaAlchemist
I’m having a very similar issue. As soon as I installed Windows, I noticed artifacting. When I was on Linux, I didn’t notice any, except for recently when I saw one, but on Windows, it’s all over the screen, though it comes and goes (meaning the screen is clear than I see a few artifacting pixels dancing around the screen and disappears going back to normal screen). I’ve run Memtest, and it has passed multiple times, so I don’t think it’s a RAM issue. The temperature of the CPU is around 38 degrees Celsius or lower, so I don’t think it’s a temperature issue. I haven’t tried lowering the RAM speed to see if it fixes the issue, but based on other people’s experiences in this thread, it seems like it should. It’s strange that Linux has fewer issues than Windows. I wonder if it could be a BIOS issue? I did try to update every driver possible, but with no luck.
I’m considering RMAing the CPU if I can’t find a solution. I’ll try to do more testing. I haven’t tried using a GPU to see if it still happens, and I haven’t tried switching the microcode either.
My build:
Gigabyte Z890M Gaming X
Intel Core Ultra 7 265K
G.SKILL Trident Z5 CK RGB Series (Intel XMP 3.0) DDR5 RAM 48GB (2x24GB) 8200MT/s CL40-52-52-131 1.40V Desktop Computer Memory CUDIMM - Mirror Black (F5-8200C4052G24GX2-TZ5CRK)
Corsair RMX Series (2021), RM850x, 850 Watt
Team Force 2TB NVME
Lastly, when I was on linux, I didn't notice them on Fedora Kinoite or Mint 21 but notice one on Mint 22. I did not try using another windows besides Windows 11.
Strebor
