23761 Discussions
3D MVC through HDMI 2.0
ENev
What is audible about 3D MVC through HDMI 2.0 on the 15.47.02.4815 driver?
now it works or is it still doesn't work?
Hi NPoser.
I understand you are looking for compatibility information for 3D content through HDMI 2.0. Let me help you on this matter.
I would like to have more information about the system configuration, please run the following https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- utility and attach the results.
To attach a file, you must click "Use Advanced Editor" in the top right corner of the response box, then the "attach" option will appear in the bottom right corner of the response box.
Allan J.
ENev
Hi Allan
My PC configuration in attach
I cannot watch 3D Blu-Ray through HDMI 2.0 port
Hi NPoser.
Thank you for the report, I appreciate it.
I have been checking the graphics driver version 4815 release notes, I found that when using less than 12GB of memory you can find problems with 3D playback.
Please take a look at the link below for additional information:
https://downloadmirror.intel.com/27199/eng/15.47%20ReleaseNotes.pdf https://downloadmirror.intel.com/27199/eng/15.47%20ReleaseNotes.pdf
Allan J.
ENev
Hi Allan
This problem doesn't depend on the amount of memory. Because if I connect to the port of HDMI 1.4 in my TV then 3D is working fine but if I connect to the port HDMI 2.0 then 3D stop working.
The same problem is in INTEL NUCi7
https://communities.intel.com/thread/112109 https://communities.intel.com/thread/112109
Hi NPoser.
Thank you for the information, let's keep working on the other thread for further updates on this matter. I regret to inform you that I do not have an estimated time of resolution.
Allan J.
FCart
The "other thread" you reference is 9 months old and marked "assumed answered" although it is abundantly clear in reading through it that no answer or solution of any kind has ever been provided. It is a series of people begging for Intel to respond, and no one from Intel has responded in many months. Intel reps said they replicated the problem (3D over HDMI 2.0 simply does not work as it is claimed to in Intel's marketing materials) but have never stated anything about a solution of any kind. Sending this thread to that black hole is totally ignoring a clear problem and burying it yet again.
Hi quoix,
This thread /thread/112109 https://communities.intel.com/thread/112109 is handled by engineering, I am sorry they still have not posted an update, they are still working to get this issue fixed. Please keep on checking the linked thread.
Allan J
SSat
Can you confirm why maryt_intel does not think this is an issue to be fixed?
"This thread /thread/112109 https://communities.intel.com/thread/112109 is handled by engineering, I am sorry they still have not posted an update, they are still working to get this issue fixed. Please keep on checking the linked thread."
The above to me states what we all know that you WERE trying to fix an issue, but now are denying it was ever an issue!
Now you have very Kindly locked the above mentioned thread also.
Trying to silence everyone and brush this under the carpet?
MArer
Unfortunately i can confirm, that 3D MVC playback still doesn't work and it seems that INTEL isn't be able or isn't willing to solve this bug. I will wait for Ryzen APU's next spring and i will then build a new HTPC on Ryzen.
FCart
Checking? Been doing that for many months, with no response from Intel. Linked thread you refer to is far less then worthless. Just a bunch of frustrated media buffs venting on the lack of response from Intel. And of course Intel would never ever admit to the lack of advertised functionality in their processors, so delay delay delay is the only option. Can't acknowledge lies or people might want refunds.
