23634 Discussions
ARC a310 : Debian Drivers please
indirectelex
I would like to see a set of drivers for the ARC a310 compatible on Debian but also more specific compatible with proxmox and truenas.
JeanetteC_Intel
Hello indirectelex,
I'll check on this request and I will post an update once it's available.
Jeanette C.
JeanetteC_Intel
Hello indirectelex,
Greetings!
I'm still further checking this issue you raised. I just need to know what his use case with the Intel® Arc™ A310 Graphics would be?
 I will wait for your reply.
JeanetteC.
Olixa4u
I understand your need for compatibility across these platforms. While ARC a310 drivers are primarily designed for more common operating systems, having support for Debian, Proxmox, and TrueNAS would be incredibly beneficial for many users in similar setups. Your best bet might be to check if there are any community-driven efforts or unofficial drivers available. Sometimes, the open-source community steps in where official support is lacking. You might also want to reach out directly to Intel or explore any existing forums dedicated to ARC GPUs to see if others have found workarounds. A strong collective push from the community could help prioritize this in future driver updates.
JeanetteC_Intel
Hello indirectelex,
Good day.
I am waiting for an update regarding the information I requested to further check this issue. Kindly let me know about this information so I can identify the next steps that need to be taken to solve this issue.
Jeanette C.
JeanetteC_Intel
Hello indirectelex,
Good day to you.
I still have not received your answer to my previous question regarding the "use case with the Intel® Arc™ A310 Graphics".
Moreover, kindly check the following:
  • Intel actively collaborates with various upstream projects to enable the best possible experience using the software and drivers provided by operating system distributions. However, because of release schedules and certain features that may not yet be available upstream, we also offer direct access to our packages and drivers.
  • You may follow the driver installation at Installing Client GPUs — Intel® software for general purpose GPU capabilities documentation
  • Regarding your concern with the usage of the Arc A310 with proxmox and truenas, I need to set your expectation that these technologies utilize virtualization. Intel Arc does not support virtualization as discussed in the article: Graphics Virtualization Technologies Support for Each Intel®...
  • Can you possibly clarify your use cases with the Intel® Arc™ A310 Graphics?
JeanetteC.
JeanetteC_Intel
Hello indirectelex,
I'm following up to check whether you have had the chance to review our prior correspondence. If you have, kindly acknowledge receipt and do not hesitate to reach out if there are any aspects you'd like to discuss or require further explanation on.
JeanetteC.
NormanS_Intel
Hello indirectelex,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Norman S.
