22940 Discussions
ARCA380 graphic card lagging in every problem without any issue
Ramim_78
Dear Intel Support Team,
I am writing to report a serious performance issue with my Intel Arc graphics card. The GPU is only 1 month old, yet it is causing serious lag in almost every game, even though my system meets all requirements.
I have already tried the following steps, but nothing has helped:
  • Re-installing the Intel Graphics Drivers
  • Updating Windows
  • Checking temperatures and fan speeds
  • Verifying game files
  • Ensuring PSU and hardware are functioning normally
Despite all these steps, the problem continues. This is highly disappointing, especially for a new GPU.
My system details:
  • Processor: Ryzen 5 5500
  • GPU: Intel Arc A380 (1 month old)
  • RAM: 8GB DDR4 3200MHz
  • Motherboard: MSI B450M-A Pro Max II
  • OS: Windows 10/11 (your version)
I kindly request your assistance in resolving this issue as soon as possible. If the GPU is defective, please guide me on warranty or replacement options.
Thank you,
MUC
Honored Contributor I
Please check if the "Resizable BAR" function is enabled on your motherboard.
Entering MSI UEFI BIOS Setup:
Press Delete key, when the Press DEL key to enter Setup Menu, F11 to enter Boot Menu message appears on the screen during the boot process.
Navigate to Settings > Advanced > PCIe > PCI Subsystem Settings an enable Re-Size BAR Support:
Next, click the X in the upper right corner to close and select "YES" to confirm Save configuration and exit:
The system will reboot.
