23854 Discussions
ASUS N3150M-E
Denis1
Hi, need driver for VGA Windows 7 32-bit !!!
IUman
Hello tirrel,
Thank you for joining the Intel communities.
You will need to get the drivers for this ASUS system from the ASUS website, ASUS is the one who can provide you with drivers, you should be able to download them at:
https://www.asus.com/Motherboards/N3150ME/ https://www.asus.com/Motherboards/N3150ME/
The drivers will be under support tab and then select drivers and tools, all the drivers available for your system will be there.
Ivan
