22824 Discussions
Accidentally uninstalled intel graphic card
SWija4
Hi guys, 2 days ago i am accidentally uninstalled my intel graphic card (i had nvidia graphic card installed too). Then, i change my pc processor and motherboard. Now i am using intel i5-7500 and when i find the intel graphic card for i5-7500 driver in the intel download center i couldnt install it due to the computer requirement. can you guys suggest any solution for me? thanks!
i attached the spec scanned using system support utility~ thanks!
Stefan3D
The iGPU is not listed in your report. Activate it in BIOS -> advanced settings -> graphics configuration.
Try this driver https://downloadmirror.intel.com/27484/a08/win64_15.65.3.4944.zip https://downloadmirror.intel.com/27484/a08/win64_15.65.3.4944.zip
To bypass message "best driver is already installed", "customized computer manufacturer driver" or "computer is not validated" install driver via have disk method as described at:
https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface (ignore prolog about MS surface)
SWija4
hii thanks for your response.
Indeed now i can installed the intel graphic card now. As my nvidia graphic card is quite old (nvidia 630 8GB) i am thinking to use the intel graphic card for primary monitor and the nvidia only for the game i think? do you know how to set it up?
right now the NVIDIA is used for everything. I tried to change the primary monitor setting in BIOS into cpu graphic card but it doesnt change anything..
Thanks for your suggestion
