22828 Discussions
Acer Aspire one model no. A0A 150
i've had my netbook for about 1 and a half years, and never had aproblem with it.
this January it had to get a BIOS upgrade so i sent it to a Acer service center for them to do it.
a month later my screen resolution started having problems
i downloaded all the new drivers
but they only work temparily, till i shut down the netbook
is there any hope to my unusual problem?
help will be much appriciated
my chipset is mobile intel(R) 945 express chipset family
OS Windows XP home edition SP3
BIOS Version 3310
any other info please ask
would like a permanant solution
I uninstalled all drivers and still presists is there anywhere i can change the settings of my screen?
ROBERT_U_Intel
This looks like it may be an issue with the display connection. I would recommend you contact ACER for again support.
Yes, it seems hardware related problem to me too.
PV.
thank you your answer, but im in another country and it cost a lot for them to just diagnose it.
but when i uninstall everything it goes back
or if i install the drivers again
the reboot ruins it
i've opened it already no cable seems altered
is there a .config file or some editing file for me to alter any sttings?
Sorry, not that I'm aware of.
Try installing the driver provided on Acer's* web site.
This seems like it is not recognizing your monitor correctly, but this will be the first time I see something like this.
PV.
i have downloaded both the chipset and the vga driver, both installed, it fixes the screen but when i shut down for the night and turn it back on in the morning it would reset to mirroring and the black bar on the side like from top pics.
ive tried updating the drivers for both monitors and chipsets to what they are supposed to be, but still nothing
Im no expert but are there suppost to be two of the same chipsets?
or this?
Yes, it is normal because of the dual pipe.
Have you tried reinstalling the operating system in your computer, install the chipset driver and then the video driver?
PV.
umm can without the OS cd? or a cd driver.
If you mean not using an actual CD because your system does not have an optical unit then yes, it can be done with a flash drive, but it is a very long and tedious job. You can fins it all over the Internet but note that you will loose a bunch of time.
I don't have one of those notebooks, but I heard that they have a partition with the restore system information and sometimes with a copy of the operating system. You can try that.
PV.
sorry i want the system restore( to factory settings) to be a last option
need to find a spare drive to dump all my stuff into
is there a way to delete everything single file that remains after i uninstall the chipset, driver and accelerator
also does this mean anything?
was my log after my last uninstall
3/12/2010 08:57:19:875
[Installer]
Installer Version: 1.1.4.0
Date Compiled = Wed Mar 21 11:34:17 2007
Commandline = -uninstall
[Resources]
Found DLL = C:\WINDOWS\system32\Lang\HDMI\ENU\HDMIENU.dll
Selected DLL = C:\WINDOWS\system32\Lang\HDMI\ENU\HDMIENU.dll
!!! ERROR 0x2: Error opening registry key
[Uninstall]
Wait for event was signaled propertly.
Uninstall Progress Dialog Launched
UninstallCustom called
UninstallINF called
UninstallINF PrePost
UninstallINF PostPost
32 bit DifxUninstall called
DIFXEVENTLOG: 0: 17971140
DIFXEVENTLOG: 0: 17972172
DIFXEVENTLOG: 0: 17974892
DIFXEVENTLOG: 0: 17981836
DIFXEVENTLOG: 0: 1798...
I believe that the system restore will be your only option at this time.
well shoot
i guess if thats my only option left, ill do it
thanks for your help, now got to go find a hard drive to dump all my files to restore netbook
much appriciated, ill get back to you if system restore work or not
i have done the system restore and still have the same problem
i am really frustrated, wish there was a way to solve this without spending too much money
