23854 Discussions
Acer Intel HD Graphics 620 Driver Update Problem
SG14
Hi
I try update my graphic driver in my new Acer laptop but i see this message in intel-driver-support-assistant
"A customized computer manufacturer driver is installed on your computer. The Intel Driver & Support Assistant is not able to update the driver. Installing a generic Intel driver instead of the customized computer manufacturer driver may cause technical issues. Contact your computer manufacturer for the latest driver for your computer."
In producent site, last driver is from september
Intel HD Graphic 620
Driver version 22.20.16.4815
Driver Date 9/26/2017
Any option update to actual ?
Stefan3D
Try drivers from this list https://downloadcenter.intel.com/product/96551/Intel-HD-Graphics-620 Downloads for Intel® HD Graphics 620
Select OS from right pull-down menu. Hit "show more".
To bypass message "best driver is already installed" or "computer is not validated" install driver via have disk method as described at:
https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface
(ignore prolog about MS surface)
NB: current drivers for Windows 10 require anniversary update or newer.
Stefan3D
SG14
