23533 Discussions
After return from screen turn off or sleep windows collapse on top left. Only DP type outputs. I read in the forums that the problem is not solved for maybe 7 years.
alsta
Microsoft Windows 10 Enterprise (64-bit)           version 1809
Intel® Core™ i7-8700 CPU @ 3.20GHz
Intel® UHD Graphics 630
Driver Version  25.20.100.6444
Motherboard Manufacturer      Gigabyte Technology Co., Ltd.
Motherboard Product   B360M-D3P-WG-CF
BIOS Version    F5
n_scott_pearson
Yes, and you will also see NVIDIA and AMD card exhibiting this same issue. I have a GTX 1060 card that does it regularly. Many (including me) consider this to be a Windows bug. A lot of work has gone into workarounds for this issue; none has worked perfectly (obviously).
alsta
Whose is this error? I guess DP cables lose power during sleep and then fail to return to their original state. What is mocking from consumers: Intel or Microsoft? Shame. Meanwhile, Microsoft created paint_3D but did not remove the bug.
