23781 Discussions
Agp Problem in Game
Zaken
I'm having an AGP problem in the game I'm playing and I found out it's related to the video card. What is the reason for this, is it because it doesn't support older games? Can you help me with this I am sending you sample pictures. I think I am having this problem because the game is old even though AGP seems to be enabled. The game I am playing is Lineage 2 High Five Edition
RandyT_Intel
Hi @Zaken,
We recommend contacting the game or application vendor to get a setting or update that allows the game or application to check for local video memory first.
Having the AGP Texture Acceleration setting as Not Available is a normal and expected behavior for the Intel Graphics Drivers (production versions 14.0 or greater). This setting doesn't need to be made available, enabled, or activated, and doesn't affect the performance of games or 3-D applications.
When a game or application is checking for AGP or AGP Texture Acceleration, it is looking for non-local memory. Generally, local video memory is usually faster than non-local.
You may check this article for more information: AGP Texture Acceleration Shows Not Available
Randy T.
RandyT_Intel
Hi @Zaken,
Randy T.
Zaken
Hello, yes, I have examined it. Although it does not affect the game performance, I think it breaks some features, which is a big problem for me. I never had this problem with Nvidia video cards. I have this problem with AMD and Intel cards. I have 2 different Intel graphics cards with this problem and I think you mean to say that the problem will not be solved. Because there is no setting to be done on the game side and cannot be done.
RandyT_Intel
Hi @Zaken,
Could you please specify which feature is being affected by this issue?
Also, have you already contacted the game or application vendor to check if there’s a setting or update available that allows the software to prioritize local video memory?
Lineage2 SUPPORT-SUPPORT
Randy T.
RandyT_Intel
Hi @Zaken,
Since I haven't heard from you, I will proceed with closing this case. Please note that it will no longer be monitored. However, you may submit a new ticket if you need further assistance in the future.
Randy T.
