23851 Discussions
Align pointcloud data to rgb data
JLH
Hi! I got a problem when I was using realsense D435i camera.
I recorded only the generated point-cloud data and RGB image WITHOUT alignment.
It turns out to be: my point-cloud data (or the depth image generated by point-cloud) has the same pixel number with RGB image, while the vision field is different. As shown in attached file, left is the point-cloud plotted, middle is the depth image generated by point-cloud, right is the RGB image.
I'm wondering is there any method that can align the point-cloud with RGB image from my stage. Since the method I can find on google is all about aligning using the RGB and depth frame, while I didn't save those frames.
Thanks anyone for help!!!!!!!!!!!
DeividA_Intel
Hello JLH,
I would like to let you know that we have a specific forum for the Intel® RealSense™ issues and products. There you will receive the appropriate support on this and other concerns you may have related to this product.
Here you will find the links to access the website and the community forums:
- https://www.intelrealsense.com/
- https://support.intelrealsense.com/hc/en-us
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
