23529 Discussions
Application has been blocked from accessing graphics hardware
PKraf1
I want a answer to this problem I don't know how to solve it plss
reply
Hello, @Paul_krapf:
I am going to need more information in regard to your system in order to address this issue, so please provided me with the following;
To attach a file, you must click "Use Advanced Editor" in the top right corner of the response box, then the "attach" option will appear in the bottom right corner of the response box.
Amy.
@Paul_krapf,
I wanted to check on your thread; does the issue persist? I would like to take a better look at your case, so if the issue persist reply with the information requested above.
Thank you.
Amy.
