23069 Discussions
Arc 770 16 GB
kostasv
Does this equipment support the Intel Arc 770 16 GB video card, as well as the Resizable Bar function? I didn't find a supported one in the list.
MUC
Honored Contributor I
System Model: MS-7B58
BIOS: 1.A0 (type: UEFI)
Processor: Intel(R) Core(TM) i5-8600K CPU @ 3.60GHz (6 CPUs), ~3.6GHz
What Is Resizable BAR and How Do I Enable It?
If you perform a BIOS Update, then you'll probably be able to activate Resizable BAR.
https://www.msi.com/Motherboard/Z370-GAMING-M5/support
Jean_Intel
Hello kostasv,
Thank you for posting in the Intel Communities. We would be more than happy to help you with your questions about the support for the Intel Arc 770 16 GB video card with your system.
The information provided by Muc is important to consider, so we would recommend you take a look at the previous post. However, we wanted to jump in the thread to inform you that for Intel Arc A Series graphics, we recommend using 10th generation, or newer processors. Additional platforms/motherboards not listed below and with Resizable BAR / Smart Access Memory enabled may also support Intel® Arc™ A-Series graphics, but our system recommendations listed in the article "Intel® Arc™ A-Series Graphics – Desktop Quick Start Guide" are for optimal performance in all applications using Intel® Arc™ A-Series Graphics.
Best regards
Jean O.
Jean_Intel
Hello kostasv,
Since we haven't heard back from you, we will close this case. This thread will no longer be monitored, so please submit a new question if you require any more information.
Best regards
Jean O.
