22796 Discussions
Arc 770 does not have higher resolution on second monitor
PCGoon
I have two Dell 2560x1440p monitors connected to Arc 770 GPU card. Since about two months ago one of them now has the highest resolution of 1920x1080p. No matter what I do, I can not change it back to 2560. Other monitor resolution is fine. There is no problem with the monitors. I swapped the HDMI cable and the resolution is the same. I think this matches with one of the updates. What am I suppose to do ? I am running Windows 11 Pro. These two were working fine until this update . . .
Andres_Intel
Hello PCGoon,
Thank you for posting on the Intel®️ communities. I see that your Dell monitors used to run at 2560x1440p and after an update now the Intel® Arc™ A770 Graphics is not working fine, I will be glad to help you.
To understand this situation in a better way, please answer the following questions:
Andres P.
Andres_Intel
Hello PCGoon,
Were you able to run the Intel® SSU report to check your system information?
Andres P.
Andres_Intel
Hello PCGoon,
Andres P.
PCGoon
I have been replying to email and it seems not working.
What are the Dell monitors model? -
Dell 27 Curved Gaming Monitor - S2722DGM, 68.58cm (27.0"), VA,165Hz,1ms (MPRT), FreeSync Premium
Are both monitors connected through HDMI? - YES
Which are the graphics driver versions that the monitors work properly? I DONT KNOW
Current : Display Adapter(s):
Preview attachment Display_scan.txt
Intel(R) Arc(TM) A770 Graphics 31.0.101.4824
AlHill
@PCGoon   Attach your txt file to the thread.  I am not going to log in to gmail to read it.
PCGoon
This is my scanned results.
PCGoon
I reset all monitor settings and still DP output from the card does not support 2560 native resolution.
