23489 Discussions
Arc B580 and llm-scaler
mathz
Does llm-scaler support Arc B580?
I'd like to add another GPU to my B60 to have a bit more VRAM and B580 seems to be the best value option, if it works that is 😊
Mike_Intel
Hello mathz,
  1. May I know why do you want to have this configuration?
  2. Does your board support this configuration?
Michael L.
mathz
Hi Mike,
thank you for your response.
Yes my motherboard easily support multiple GPUS (I've got a Arock Rack Romed8-2T). And I'd like to use it for inference.
Mathz
mathz
Forgot to mention: I'm using llm-scaler at the moment, so my main conern if is llm-scaler can recognize B580.
JedG_Intel
Hi mathz,
Thank you for sharing all this information. I'll check all the details and I'll get back to you as soon as possible.
Jed G.
Mike_Intel
Hello mathz,
Thank you so much for patiently waiting for our update.
As for your inquiry, here is my update:
Support for using two Arc GPUs for LLM inferencing is available through IPEX-LLM. For further details, you may also check these links:
Multi Intel GPUs selection — IPEX-LLM latest documentation
IPEX-LLM — IPEX-LLM latest documentation
ipex-llm/python/llm/example/GPU/Deepspeed-AutoTP/README.md at main · intel/ipex-llm · GitHub
Michael L.
mathz
Hi Michael,
Unforunatly it does not answer my question.
I'm aware that llm-scaler can utilize multiple GPU's. The question is if it is an viable option to combine B60 and B580 in one setup.
Since both have the same architecture, I can go into more detail about their different VRAM capacities and rephrase the question:
Can you use the entire VRAM of both cards if they have different VRAM capacities, or does the software fall back on the lowest common denominator (in this case 12 GB, for a total of 24 GB instead of the available 36 GB)?
Mathz
Mike_Intel
Hi mathz,
Thank you for the clarification. Let me check this again and update this thread once I have an update.
Michael L.
Mike_Intel
Hi mathz,
Upon further checking, I am really sorry because we have very limited information in regard to this configuration.
However, the expert in this domain is via GitHub page below.
Intel® Corporation · GitHub
Since you are now being directed to GitHub. I need to close this inquiry.
Michael L.
