23455 Discussions
Arc Pro B70 card permanently downgraded from PCIe Gen5 x16 to Gen4 x16
mwaustin
New User
I have a pair of B70s - one of which negotiates PCIe @ Gen5 x16, the other of which negotiates PCIe @ Gen4 x16.  This happens if I switch slots on either of two different motherboards from two different manufacturers.  (All four combinations - motherboards involved are Asus WS WRX90E-SAGE SE and Gigabyte AI TOP.). The Gen4 negotiation follows the physical card - not the slot(s) involved.
Given one other post expressing a similar problem with the B70, at this point is this a known problem?
Do I need to contact warranty support - and exchange the apparently defective card - or is this something that will be fixed with a firmware upgrade?
mwaustin
New User
While trying further to figure out what was going on - I stumbled upon: "xpu-smi config" which displays a "PCIe Gen4 Downgrade" option - which was enabled.  I disabled this option - and PCIe Gen5 is back!
Hope this helps someone!
