23487 Discussions
Arc driver installation failed on Ubuntu 22.04.5 LTS
ChrisMa
I followed the driver installation instructions (https://dgpu-docs.intel.com/driver/client/overview.html) to install Arc770 driver on Ubuntu 22.04.5 LTS, but throw below error and thus I am not able to successfully execute apt update due to invalid release file.
wget -qO - https://repositories.intel.com/gpu/intel-graphics.key | \
sudo gpg --dearmor --output /usr/share/keyrings/intel-graphics.gpg
gpg: no valid OpenPGP data found.
Linux kernel is 5.15.0-119-generic, any workaround to tackle this issue?
Thanks and best,
Chris
Mike_Intel
Hello ChrisMa,
I will do further research on this matter and post the response on this thread once it is available.
Thank you very much for your patience and understanding!
Michael L.
ChrisMa
Hi Michael,
Thanks for the reply. Recently I'm aware it could be the unsynchronized system time issue which leads to SSL check failure (see below screenshots). I'm asking for internal team to look into it. And I will let you know in case of any findings.
Best,
Chris
Ernesto_C_Intel1
Hi ChrisMa,
Thank you for sharing the additional information regarding the issue. I've tried to simulate the issue that you've encountered by installing the latest available copy of Ubuntu 22.04.5. Based on my checks, the default version comes with kernel version: 6.8.0-49-generic pre-installed.
Following the instructions from https://dgpu-docs.intel.com/driver/client/overview.html
I was able to install the Arc Graphics driver for an Intel A770 graphics driver with no major issues. Since you're checking internally, I'll move our discussion internally as well.
Ernesto C.
ChrisMa
Hi Ernesto,
Thanks for the updates.
Based on your findings I'm certain this issue is due to other reasons e.g. unsynchronized system time instead of driver issues.
So let me follow up the internally raised case and I think it's fine to close this ticket.
Much appreciated for looking into this.
Best,
Chris
Ernesto_C_Intel1
Hi ChrisMa,
Thank you for letting me know. I'll go ahead and close this ticket on my end.
Feel free to contact us if you need our assistance.
Ernesto C.
ChrisMa
Hi Ernesto,
Unfortunately I'm still facing this issue although the system time is synchronized. Most probably it's a PUBLIC KEY not signed issue.
(base) sdp@sdp:~$ wget -qO - https://repositories.intel.com/gpu/intel-graphics.key |   sudo gpg --yes --dearmor --output /usr/share/keyrings/intel-graphics.gpg
(base) sdp@sdp:~$ echo "deb [arch=amd64,i386 signed-by=/usr/share/keyrings/intel-graphics.gpg] https://repositories.intel.com/gpu/ubuntu jammy client" | \
  sudo tee /etc/apt/sources.list.d/intel-gpu-jammy.list
(base) sdp@sdp:~$ sudo apt update
Hit:1 https://repositories.intel.com/gpu/ubuntu jammy InRelease
Get:2 http://security.ubuntu.com/ubuntu jammy-security InRelease [129 kB]
Get:3 https://apt.repos.intel.com/oneapi all InRelease [5,680 B]
Hit:4 http://archive.ubuntu.com/ubuntu jammy InRelease
Err:3 https://apt.repos.intel.com/oneapi all InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY BAC6F0C353D04109
Get:5 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [128 kB]
Hit:6 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
Reading package lists... Done
W: GPG error: https://apt.repos.intel.com/oneapi all InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY BAC6F0C353D04109
E: The repository 'https://apt.repos.intel.com/oneapi all InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Similar open:
https://community.intel.com/t5/GPU-Compute-Software/Public-key-not-available-NO-PUBKEY-28DA432DAAC8BAEA/m-p/1653755
So, could you help look into it again, thanks!
Best,
Chris
Martin_HZK
I encounter this issue either!
hzk@xiaoran-x99:~$ sudo apt update
[sudo] password for hzk:
Hit:1 http://cn.archive.ubuntu.com/ubuntu jammy InRelease
Hit:2 http://cn.archive.ubuntu.com/ubuntu jammy-updates InRelease
Get:3 http://security.ubuntu.com/ubuntu jammy-security InRelease [129 kB]
Hit:4 http://cn.archive.ubuntu.com/ubuntu jammy-backports InRelease
Get:5 https://repositories.intel.com/gpu/ubuntu jammy InRelease [15.4 kB]
Get:6 https://repositories.intel.com/gpu/ubuntu jammy/unified i386 Packages [64.2 kB]
Err:6 https://repositories.intel.com/gpu/ubuntu jammy/unified i386 Packages
  File has unexpected size (65752 != 64195). Mirror sync in progress? [IP: 192.168.1.233 7890]
  Hashes of expected file:
   - Filesize:64195 [weak]
   - SHA512:2712386f14c8586a3e7997fe6786670c687a26b0843fed250118e83e7b31cb7868854e9394397677e660c41862bdc1f827b876df9605c45fe35bf0a22ccccca5
   - SHA256:ac44edde47c39ee7b7b6f70599d5323d80e48609c542c967ccbc7a4a488de850
   - SHA1:f7e4e46bdbbdb59725fddb15c714f2d1cf0c1546 [weak]
   - MD5Sum:5eccd977e571acc69ac010a270149934 [weak]
  Release file created at: Thu, 06 Feb 2025 16:03:10 +0000
Get:7 https://repositories.intel.com/gpu/ubuntu jammy/unified amd64 Packages [205 kB]
Err:7 https://repositories.intel.com/gpu/ubuntu jammy/unified amd64 Packages
Fetched 144 kB in 4s (35.5 kB/s)
E: Failed to fetch https://repositories.intel.com/gpu/ubuntu/dists/jammy/unified/binary-i386/Packages.gz  File has unexpected size (65752 != 64195). Mirror sync in progress? [IP: 192.168.1.233 7890]
E: Failed to fetch https://repositories.intel.com/gpu/ubuntu/dists/jammy/unified/binary-amd64/Packages.gz
E: Some index files failed to download. They have been ignored, or old ones used instead.
 When I update it, it just return this error
