Hi Raziuri,
To answer your question, Arc B580 and B570 are more optimize on running newer games that run on DX12.
Source link: Supported APIs for Intel® Graphics
But unfortunately, Team Fortress 2 runs on DX 9, you may encounter some compatibility issues with it.
Source link: TF2 and DirectX 12 :: Hardware and Operating Systems
May I know if you were able to run Team Fortress 2 on your Arc B580 or 570?
Do you encounter any issues with it? any error messages?
Earl E.
Thanks for the info, I was asking because I plan to get either the B580 or B570 for my pc build (depending on availability), and i was wondering if some of the older games in my library will work. as for if it ran, I'll update you on that as soon as i can get my hands on one of the card and test it.
If I remember correctly TF2's 64 bit version does have experimental Vulkan support.
https://steamcommunity.com/sharedfiles/filedetails/?id=3228732058
Should give instructions on how to enable it. I imagine that would work well. I may check on my ARC setup later.
Team Fortress 2 is running just fine on my B570 with highest settings
I just purchased my Intel ARC B580, and my favorite older game Soldier of Fortune 2, older Directx 9 game, it will not launch into the game. I tried numerous times, I am using Windows 11, the game worked fine on my previous graphics card RTX 4060ti. I play this game every day so if you guys have anything you can assist with getting this game to launch would be great, otherwise I have to return it.
just got an arc B580, TF2 works and runs at a good fps, but there is occasional stuttering and game freezing
