23783 Discussions
Assistente de driver e suporte Intel
DonatoBrasileiro
Oi, então meu aplicativo de atualizar driver e placa de video por algum motivo não funciona, eu abro ele para " verificar se há novos drivers " porem diz que não possuo o aplicativo baixado, tento baixar novamente e reiniciar o computador mas de nada adianta
David_G_Intel
Hello DonatoBrasileiro
Thank you for posting on the Intel️® communities. Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
To confirm, your current problem is with Intel® DSA showing the error on red, is this correct? Please share with us more information:
  • Which browser do you use?
  • Did it work properly before?
  • Which troubleshooting steps did you try?
  • Do you know the DSA version used?
David G
David_G_Intel
David G.
David_G_Intel
David G.
