23854 Discussions
At my wit's end.
I am experiencing a problem whereby everytime I boot the PC from cold I get a BSOB screen caused by USBPORT.SYS.
Currently I am running Windows Vista Ultimate 64 with SP2 and prior to this OS I was running Vista Ultimate 32 also with SP2.
This problem has occured on both versions of Vista but never when I was running Windows XP SP3.
Once the PC reboots after the crash I am always able to login to Windows and Microsoft applet connects to the internet and
tells me that my boot failure was due to a USB driver.
I only have 4 devices connected to USB ports.
A logitech mouse
An external Seagate Disk
2 joysticks
With the exception of the mouse I have disconnected all the other USB devices but problem still persists.
I am also running the latest BIOS available for the Motherboard which is an Asus P5E3 WS Pro.
Have also updated to the latest Inter Chipset drivers for the X38 chipset here: http://support.intel.com/support/chipsets/sb/CS-026488.htm.
Not sure if there are any more Intel drivers to update or how to resolve this issue. Very grateful for any advice. If more info is required
please let me know.
SPECS:
CPUID Properties:
CPUID Manufacturer GenuineIntel
CPUID CPU Name Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
CPUID Revision 000006FBh
IA Brand ID 00h (Unknown)
Platform ID 29h / MC 10h (LGA775)
Microcode Update Revision B6
HTT / CMP Units 0 / 4
Tjmax Temperature 100 °C (212 °F)
Instruction Set: 64-bit x86 Extension (AMD64, Intel64) Supported
[ North Bridge: Intel Beachwood X38 ]
North Bridge Properties:
North Bridge Intel Beachwood X38
Supported FSB Speeds FSB800, FSB1066, FSB1333
Supported Memory Types DDR2-667 SDRAM, DDR2-800 SDRAM, DDR3-800 SDRAM, DDR3-1066 SDRAM, DDR3-1333 SDRAM
Maximum Memory Amount 8 GB
Revision / Stepping 01 / A1
Package Type 1300 Pin FC-BGA
Package Size 4.0 cm x 4.0 cm
Core Voltage 1.25 V
In-Order Queue Depth 12
Memory Controller:
Type Dual Channel (128-bit)
Active Mode Dual Channel (128-bit)
Memory Timings:
Latency (CL) 9T
RAS To CAS Delay (tRCD) 9T
RAS Precharge (tRP) 9T
RAS Active Time (tRAS) 24T
Row Refresh Cycle Time (tRFC) 60T
Command Rate (CR) 2T
RAS To RAS Delay (tRRD) 4T
Write Recovery Time (tWR) 19T
Read To Read Delay (tRTR)Same Rank: 4T, Different Rank: 7T
Read To Write Delay (tRTW) 10T
Write To Read Delay (tWTR) Same Rank: 15T, Different Rank: 5T
Write To Write Delay (tWTW) Same Rank: 4T, Different Rank: 7T
Read To Precharge Delay (tRTP) 6T
Write To Precharge Delay (tWTP) 19T
Precharge To Precharge Delay (tPTP) 1T
Refresh Period (tREF) 16383T
DRAM Read ODT 3T
DRAM Write ODT 7T MCH Read ODT 8T
Performance Level 7
Read Delay Phase Adjust Neutral
DIMM3 Clock Fine Delay 4T
DIMM4 Clock Fine Delay 4T
Error Correction:
ECC Supported, Disabled
ChipKill ECC Not Supported
RAID Not Supported
ECC Scrubbing Not Supported
Memory Slots:
DRAM Slot # 1 2 GB (DDR3-1066 DDR3 SDRAM)
DRAM Slot # 2 2 GB (DDR3-1066 DDR3 SDRAM)
PCI Express Controller: PCI-E port # 3 In Use @ x16 (Asus EN8800GT Video Adapter)
Chipset Manufacturer:
Company Name Intel Corporation
Product Information http://www.intel.com/products/chipsets
Driver Download http://support.intel.com/support/chipsets Driver Update http://driveragent.com?ref=59
