23758 Discussions
Audio Prob in DG965RY.
no sound when i have installed new motherboard dg965ry. drivers have installed propely. IDT. volume icon is also there on the task pannel but vry vry low volume. Is there any seting prob...? please help me with this....
I am not sure about this, but try checking BIOS setting if audio is enabled. Secondly, you can see there is a white socket at a corner near a white slot and a yellow socket between two white slots. I do not know which one is Audio, but try removing any wire plugged in any of these sockets. I guess most probably the yellow socket is the audio socket.
yo tengo un problema con la linea de entrada. no se puede configurar ni se puede habilitar. por lo que veo son muchos los problemas de audio que tienen high definition audio con windows 7. Recien hable con un tecnico de intel por chat y me dijo que no van a solucionarlo que tengo que adquirier otro hard compatible. quiero que tengan en cuenta que el resto de las empresas si esta dando soporte como corresponde ej. assus,msi,gyga,etc. espero una pronta respuesta. y seria.
I have a problem with the input line. can not be configured or can be enabled. I see many audio problems that have high definition audio with windows 7. Latest speak with an Intel technical for chat and told me not going to solve that I bought another hard compatible. I want to take into account that the other companies if this instance giving support accordingly. Assus, msi, gyga, etc.. I expect a prompt response. and serious.
