23586 Discussions
B580 HDR issue in DIY Monitor
Mr_Tadokoro
I am encountering an issue with my Intel B580 GPU when using a DIY display setup. The display consists of a panel (AUO B160QAN02.2) and a pass-through board connected via eDP interface. The pass-through board links to the GPU via DisplayPort (DP)
This pannel support 10bit color + 240Hz +HDR. But the GPU only provides a 6-bit depth potion at 240Hz refresh rate. If forcing 10-bit color by Intel Graphics Command Center, the system automatically enables HDR and locks the refresh rate to 60hz, the display exhibits a washed-out/grayish appearance unless HDR is manually enabled.
The same setup works flawlessly with an NVIDIA GPU, it allowing simutaneous 10-bit, HDR, 240Hz refresh rate without issues.
when using a commercially available display, B580 dose not exibit the aforementiones issue and can support 10-bit color with HDR at 240Hz.
DhannielM_Intel
Hello Mr_Tadokoro,
Thank you for posting in the community. It seems you're using a custom-made monitor panel. I have a few clarifications I'd like to address regarding your setup:
  1. Are you using an eDP to DP adapter to connect your monitor to the GPU? Is this assumption correct?
  2. What is the version of DP connected to the GPU?
  3. Could you provide the exact model of your NVIDIA GPU?
  4. Are you using the latest driver version for your B580?
  5. Is there a direct DP-to-DP connection from your monitor to the GPU?
  6. Do you know the HDCP version of the monitor panel you're using?
Additionally, if you have the Intel Graphics Command Center (IGCC), could you generate the EDID of your monitor for further investigation? You can do this by navigating to the Support section and accessing the System Diagnostic panel, where you'll find a button labeled "Generate Report." This will compile all graphics information on your system, including the EDID of your monitor. Please save it as a text file and share it in this thread.
Dhanniel M.
Mr_Tadokoro
There r no eDP to DP adapter is usage. The connection path is : Intel B580 GPU → DP cable → Pass-through Board → eDP interface → AUO B160QAN02.2 panel.
The DP interface is DP1.4.
I had tried the RTX 3060 Ti and RTX 4080 Super. The driver Version is 536.67.
I using the latest driver on B580. The driver version is 32.0.101.6734.
A direct DP 1.4 cable connects the GPU to the pass-through board.
I can`t get the datasheet of AUO B160QAN02.2. So I couldn`t know the HDCP version.
Here is the EDID report
By the way, now I can enable 10-bit color depth at 240Hz and activate HDR on my B580. However, when HDR is enabled, the screen will turn gray, just like the display does not properly support HDR. I also try the AMD 9070 XT, is exhibit the same issue. But the NVIDIA GPUs work flaylessly with no color degradation in HDR mode.
Mr_Tadokoro
There r no eDP to DP adapter is usage. The connection path is : intel B580 GPU → DP cable → Pass-throu Board → £DP interface →AUO B160QAN02.2 panel.
The DP interface is Dp1.4.
using the latest driver on B580.The driver version is 32.0.101.6734
A direct Dp 1.4 cable connects the GPU to the pass-through board.
I can `t get the datasheet of AU0 B160QAN02.2. So l couldn`t know the HDCp version
Here is the EDlD report
By the way, now l can enable 10-bit color depth at 240Hz and activate HDR on my B580. However, when HDR is enabled, the screen will turn gray, just like the display does not properly support HDR. l also try the AMD 9070 XT, is exhibit the same issue. But the NVIDIA GPUs work flawlessly with no color degradation in HDR mode.
Haozhuang
你好,请问一下你的DP转edp驱动板是哪个,我使用我的dp转edp驱动板似乎和英特尔显卡不兼容,我的屏幕是AUO B160QAN02.3,无法自动启用dsc功能,只能使用cru  2560x1600 160hz 8bit,或者210hz  6bit,所以我想知道你用的是哪种edp驱动板,可以告诉我吗?还有你是如何240hz 6bit到10bit的?
Mr_Tadokoro
振华兄弟的DP直通板,后面我记得是问AI用CRU捣鼓了一下DSC选项解决了
Haozhuang
好的,我一会去看看,顺便问一下用cru如何开启dsc选项,我也问了AI,但是AI答不出来,所以给出方案吗?
Mr_Tadokoro
解决方案:通过 Vendor-Specific Block 添加 DSC 参数
替代方案:通过 Detailed Resolutions 强制关联 DSC
PowerShell 一键启用 DSC (Intel 显卡专用)
我记得是上面三种方案折腾到哪一种就能用了,但是具体怎么搞的我也忘了,你可以试试拿这三种方法问AI试试
Haozhuang
非常感谢您的方法,但是似乎这些方法对于这个dp直通板不管用,顺便问一下振华兄dp直通板是那种大dp头的小板还是minidp头的大板,还有可以发我一份你的便携显示器开启dsc后的EDID文件方便我来作为参考吗?
Mr_Tadokoro
我不用便携屏挺久了,EDID文件早不知道扔哪去了😂振华兄是miniDP头的小板,直通的,没转换芯片之类的。
Haozhuang
好的,麻烦你了,我立马下单,非常感谢你提供的各种资料。
Mr_Tadokoro
我刚刚又去试了一下,用这个办法就可以了
在CRU最下面那个Extension blocks的对话框,点Add,类型选DisplayID 1.3,然后再Add,类型选Detailed resolutions,再Add,Active那里填你的分辨率,Refersh rate填你的刷新率,点OK,最后在Extension blocks上面把你刚刚添加的移动到第一行就好了,然后我就能开240Hz和10bit了
Haozhuang
我按照你的方法测试过了,依旧不行,不知道你能否将你可以开240hz的EDID文件发给我供我参考,谢谢
Jie666
nonono 你这个是在detailed resolution 里面改成了2.5k 240hz 这区块的优先级是最高的 但是我修改就会报错而且还无法应用 不知道你是怎么弄的
Jie666
我去 我也是 我的型号是NE180QDM-NZ2 也是只能210hz 6bit 用振华兄的板子 还是不行 显卡是b580
MUC
Honored Contributor I
The EDID shows:
The EDID doesn't necessarily match the required structure. However, the range limits indicate that there is likely a third EDID block that the Intel Graphics Command Center isn't reporting via diagnostics.
2560 x 1600 @ 240 Hz RGB 10-bit CVT-RB = 1174.25 MHz pixel clock = 136% DisplayPort 1.4a HBR3, so DSC is required.
Please run edid-test.exe:
https://www.monitortests.com/edid-test.zip
This will create a file named "edid-test.txt" in the same folder. Please attach this TXT file here.
Mr_Tadokoro
I borrowed the B580 to my friend. I will reply in a few days.
Mr_Tadokoro
As requested, I have generated the EDID report using edid-text.exe and attached it to this message. Additionally, I have taken photos of the screen output with both the Intel B580 and NVIDIA RTX 3060 Ti GPUs when HDR is enabled.
These images clearly demonstrate the following differences:
  • Intel B580 with HDR enabled:
    • Lower brightness compared to the NVIDIA GPU.
    • Noticeably washed-out/grayish appearance, similar to an improperly calibrated HDR display.
  • NVIDIA RTX 3060 Ti with HDR enabled:
    • No brightness reduction or color degradation — HDR operates as expected.
  1. edid-test(B580).txt (EDID report)
  2. B580.jpg (HDR on B580)
  3. 3060Ti.jpg (HDR on RTX 3060 Ti)
MUC
The EDID test shows, as suspected, a third block in the EDID:
Since this also seems to work with the B580 according to your screenshot, this point seems to be resolved.
Regarding HDR, the result on a display also depends on the type of metadata sent by the source. I know from personal experience that the Nvidia and Intel drivers handle this differently. Intel and AMD drivers tend to use default values for the Luminance Range (MIN/MAX) and Content (maxCLL/maxFALL) Mapping. Typically:
Mastering display luminance:
  • Minimum (black level) = 0.01 cd/m² [= nits]
  • Maximum (peak luminance) = 1499 cd/m²
Maximum Content Light Level (maxCLL) = 1499 cd/m²
Maximum Frame Average Light Level (maxFALL) = 799 cd/m²
In contrast, Nvidia drivers without metadata from a source file (e.g., a video file) send a ZERO for all of the above values. According to the definition specified in SMPTE ST.2086, ZERO means "not present." The display must then use its own algorithms for luminance range mapping. This varies from manufacturer to manufacturer.
Your display's EDID says:
  • Desired content max luminance: 507.620 cd/m²
  • Desired content max frame-average luminance: 507.620 cd/m²
  • Desired content min luminance: 0.394 cd/m²
Have you tried setting up the display with a Windows color profile? This changes the sent metadata to avoid the problems mentioned.
Microsoft Support: Calibrate your HDR display using the Windows HDR Calibration App
Mr_Tadokoro
I have tried the Windows color profile. It can`t solve the HDR issue with B580. As u can see, the photos of screen show that the B580 with HDR is turn "grey". The problem behaves similarly to the following scenario:
When using a commercially available HDR-capable monitor, if I don`t enable HDR in the display`s OSD menu, but enable HDR in Windows, the screen will turn "gray".  In my DIY setup, even though the panel natively supports HDR, the B580 seems to fail in corrdinating HDR metedata between the OS and the displaty hardware, resuluting in the same "gray HDR" effect.
MUC
I can see the difference in your screenshots, yes. The peak brightness is also displayed differently in your Windows display settings:
  • Arc B580: 440 nits
  • GeForce RTX 3060 Ti: 508 nits
The 508 nits are in the EDID that the display sends to the computer. Where does the Arc B580 get the value 440 from? Are the screenshots from before or after running the Windows HDR Calibration app and activating the Windows color profile? If the color profile doesn't make a difference, you can also remove it again:
Don't forget to restart.
After removing it, does the peak brightness on the Arc B580 show 508 nits again?
