23542 Discussions
B580 is not optimized for capcut
Patrick74
I have an Intel Arc B580 GPU, and I’m experiencing low GPU usage (around 15%) in CapCut Desktop, even with hardware acceleration enabled.
CPU is overloaded instead, and video playback lags during color correction.
Everything lags even with the slightest color correction. I've set everything up correctly and tried a bunch of settings. This didn't happen with my old RX580 card and 3060.
System details:
- GPU: Intel Arc B580
- CPU: Ryzen 5 5600
- RAM: 32 GB
- OS: Windows 11
Rebar activated, latest driver version from October 22, 750W power supply, I've attached the file below. The program works fine on other cards.
In Premiere Pro everything loads normally, and in DaVinci Resolve too. I have clean drivers installed on a fresh Windows.
Please adjust the drivers for CapCut as well, since it works fine in Premiere
LeonWaksman
There is a new Beta version for your BIOS
I'm not sure if it will solve your problem but you may try.
Leon
Patrick74
