22939 Discussions
-BETA- 15.40.18.4380: Intel® Graphics Driver for Windows® 7,8.1,10
Bryce__Intel
IMPORTANT NOTE:Operating system support varies by platform. Due to this and a limitation of the database, Download Center search capabilities cannot report OS support accurately, so please see the support information below or reference the associated https://downloadmirror.intel.com/25749/eng/ReadMe.txt ReadMe or https://downloadmirror.intel.com/25749/eng/ReleaseNotes_GFX_15%2040%204380_Beta.pdf ReleaseNotes for more details.
BETA Notice
This beta version driver is provided to confirm pending driver code changes that address numerous reported game play issues. A list of issues addressed is contained in the ReleaseNotes. A production version driver will follow in a few weeks, if the beta tests well.
This driver is being provided as a beta test driver, and while it has had limited validation testing by Intel, it is essentially a test driver and is not to be considered a permanent replacement for a fully validated and certified graphics driver. Any issues/comments unrelated to the issues addressed in https://downloadmirror.intel.com/25749/eng/ReleaseNotes_GFX_15%2040%204380_Beta.pdf ReleaseNotes may be deleted without notice.
  • Use at your own discretion
While Intel may or may not address issues found in this beta version driver, we do welcome feedback particular to the issues listed in the ReleaseNotes that the driver addresses.
  • Please note: this driver is not certified by Microsoft* and will generate a warning when installing.
The Windows BETA driver 15.40.18.4380 has been posted to Intel Download Center at the following direct links to the driver:
This driver is in self installing format (exe) intended for end users.
32bit - NA
64bit - NA
This driver is in zip format intended for developers and IT professionals.
32bit - https://downloadcenter.intel.com/downloads/eula/25749/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40-?httpDown=https://downloadmirror.intel.com/25749/eng/Beta_15.40.18.4380.zip Intel® Beta Graphics Driver for Windows® 7/8.1/10* [15.40]
<span style="font-weight: inherit; font-style: inherit; font-size: 12pt; font-family: calibri, ve...
FScho1
I already tried the 4404. Currently it's the latest Dell one. I hang in the dell hotline for about one hour and they told me to contact baad Intel 😉
CCris2
New Contributor II
Well, there are some issues with the driver atm. You should post on what application / game you have problems, so they can look into it.
FScho1
Hardware configuration: It's a Dell XPS 15 (9550) with i5 6300HQ and a NVIDIA Optimum configuration consisting of Intel HD Graphics 530 (20.19.15.4404) and NVIDIA 960M (2GB/DDR5; 364.72 or 358.94).
Evertime I use IE/Edge or Chrome (I didn't test any other browsers) on a WebGL website, the graphics driver of the Intel 530 crashes and Windows 10 recovers it. Immediately the frame rate drops from 60fps to less than 20fps. Some minutes later I notice text and box rendering problems in the browser windows aswell in Windows 10's window compositor.
If I assign manually the NVIDIA GPU to the browsers, they work fine! except the window compositor of Windows 10.
I didn't test any other applications on the Intel GPU but I think that it's a general poblem with 3D acceleration.
CCris2
New Contributor II
I have i7 6700k with Intel HD 530. I tried WebGL page in IE and Chrome but in Windows 8.1 Pro x64 and I had no problem at all. The intel graphic drivers have some issues. I temporary solved those issues till new driver gets released by doing the following: go to Internet Options / Advanced tab and enable 64-bit processes for Enhanced Protected Mode.
Note that this may not work for you as you have different configuration and other Operating system.
FScho1
FScho1
Well I assume in my case its a hardware bug.
Same triggering, Kubuntu...
[ 111.782708] [drm] stuck on render ring
[ 111.782947] [drm] GPU HANG: ecode 9:0:0x85dffffb, in kwin_x11 [1821], reason: Ring hung, action: reset
[ 111.782949] [drm] GPU hangs can indicate a bug anywhere in the entire gfx stack, including userspace.
[ 111.782950] [drm] Please file a _new_ bug report on bugs.freedesktop.org against DRI -> DRM/Intel
[ 111.782951] [drm] drm/i915 developers can then reassign to the right component if it's not a kernel issue.
[ 111.782952] [drm] The gpu crash dump is required to analyze gpu hangs, so please always attach it.
[ 111.782954] [drm] GPU crash dump saved to /sys/class/drm/card0/error
[ 111.782964] ------------[ cut here ]------------
[ 111.782998] WARNING: CPU: 3 PID: 1043 at /build/linux-Ay7j_C/linux-4.4.0/ubuntu/i915/intel_display.c:11385 intel_mmio_flip_work_func+0x45e/0x490 [i915_bpo]()
[ 111.783000] WARN_ON(__i915_wait_request(mmio_flip->req, mmio_flip->crtc->reset_counter, false, ((void *)0), &mmio_flip->i915->rps.mmioflips))
[ 111.783002] Modules linked in:
[ 111.783003] rfcomm bnep hid_multitouch snd_hda_codec_hdmi dell_led snd_hda_codec_realtek snd_hda_codec_generic intel_rapl x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel snd_hda_intel kvm snd_hda_codec brcmfmac snd_hda_core uvcvideo irqbypass snd_hwdep i2c_designware_platform snd_pcm i2c_designware_core brcmutil crct10dif_pclmul videobuf2_vmalloc dell_wmi videobuf2_memops sparse_keymap crc32_pclmul cfg80211 videobuf2_v4l2 videobuf2_core aesni_intel snd_seq_midi snd_seq_midi_event v4l2_common snd_rawmidi aes_x86_64 snd_seq lrw videodev input_leds gf128mul snd_seq_device dell_laptop dcdbas glue_helper media ablk_helper joydev hci_uart rtsx_pci_ms snd_timer cryptd serio_raw btusb btqca btrtl snd memstick btbcm btintel soundcore bluetooth idma64 mei_me virt_dma dell_smo8800 mei acpi_als kfifo_buf
[ 111.783046] intel_lpss_pci intel_lpss_acpi intel_lpss int3403_thermal int3400_thermal acpi_thermal_rel processor_thermal_device int3402_thermal int340x_thermal_zone shpchp intel_soc_dts_iosf mac_hid acpi_pad industrialio parport_pc ppdev lp parport autofs4 squashfs overlay nls_utf8 isofs nls_iso8859_1 dm_mirror dm_region_hash dm_log uas usb_storage rtsx_pci_sdmmc nouveau i915_bpo mxm_wmi intel_ips ttm i2c_algo_bit psmouse drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ahci rtsx_pci drm libahci i2c_hid hid video wmi pinctrl_sunrisepoint pinctrl_intel fjes
[ 111.783078] CPU: 3 PID: 1043 Comm: kworker/3:4 Not tainted 4.4.0-21-generic # 37-Ubuntu
[ 111.783080] Hardware name: Dell Inc. XPS 15 9550/0X2P13, BIOS 01.02.00 04/07/2016
[ 111.783108] Workqueue: events intel_mmio_flip_work_func [i915_bpo]
[ 111.783110] 0000000000000286 00000000acf80c02 ffff8802aca4bd20 ffffffff813e93c3
[ 111.783113] ffff8802aca4bd68 ffffffffc02aa498 ffff8802aca4bd58 ffffffff81080f62
[ 111.783116] ffff8802b326a780 ffff88024ce9bd80 ffff8802a9f14b40 00000000000000c0
[ 111.783119] Call Trace:
[ 111.783125] [] dump_stack+0x63/0x90
[ 111.783129] [] warn_slowpath_common+0x82/0xc0
[ 111.783132] [] warn_slowpath_fmt+0x5c/0x80
[ 111.783135] [] ? __switch_to+0x420/0x5a0
[ 111.783162] [] intel_mmio_flip_work_func+0x45e/0x490 [i915_bpo]
[ 111.783165] [] process_one_work+0x162/0x480
[ 111.783168] [] worker_thread+0x4b/0x4c0
[ 111.783171] [] ? process_one_work+0x480/0x480
[ 111.783174] [] kthread+0xd8/0xf0
[ 111.783176] [] ? kthread_create_on_node+0x1e0/0x1e0
[ 111.783180] [] ret_from_fork+0x3f/0x70
[ 111.783183] [] ? kthread_create_on_node+0x1e0/0x1e0
[ 111.783185] ---[ end trace 08479e5b61d3a654 ]---
[ 111.785392] drm/i915: Resetting chip after gpu hang
[ 113.782945] [drm] RC6 on
[ 324.245581] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[ 324.288092] cfg80211: Regulatory domain changed to country: DE
[ 324.288096] cfg80211: DFS Master region: ETSI
[ 324.288098] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 324.288101] cfg80211: (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 324.288104] cfg80211: (5150000 KHz - 5250000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 324.288106] cfg80211: (5250000 KHz - 5350000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 324.288108] cfg80211: (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698 mBm), (0 s)
[ 324.288110] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 470.792165] [drm] stuck on render ring
[ 470.792782] [drm] GPU HANG: ecode 9:0:0x85df3cff, in firefox [2264], reason: Ring hung, action: reset
[ 470.795207] drm/i915: Resetting chip after gpu hang
[ 471.812609] [drm] RC6 on
CCris2
New Contributor II
Lol. Is the last version of Kubuntu ?
I tested also on linux and if you don't download and recompile the latest drivers with all patches, the graphic driver will not work ...
FScho1
It is, indeed. But really: Is it possible that two different drivers by two different developer teams on two different operating systems have exactly the same bug? And a BIOS problem should affect more than one customer
CCris2
New Contributor II
It is possible to be a bios or customization driver problem. Have you tried the drivers that dell is providing ? Or updating bios ?
FScho1
I did all that. But it does't change the fact that two different drivers on two different operating systems have the same exotic bug - hanging gpu when using 3d acceleration. And this shouldn't even be the case if the kernel driver isn't fully compatible. It's loaded (mesa-utils) and used (Intel HD Graphics 530 (Skylake GT2) with OpenGL 3.3.).
CCris2
New Contributor II
I know what you mean, but you are the second person with almost same problem I see here. The other person has a problem with a laptop from MSI also with 2 graphic cards ...
In any way, I'm sorry that you have problems, but whatever problem your laptop has it will end up at dell, or from where you bought it. I don't think there is to much you can do...
CCris2
New Contributor II
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
When browsing facebook on IE 11, scrolling with page down, or sometimes even browsing computer files, I get explorer errors like this:
Problem signature:
Problem Event Name: APPCRASH
Application Name: IEXPLORE.EXE
Application Version: 11.0.9600.18124
Application Timestamp: 5641278d
Fault Module Name: StackHash_2760
Fault Module Version: 6.3.9600.18258
Fault Module Timestamp: 56d878ce
Exception Code: c0000374
Exception Offset: PCH_FB_FROM_ntdll+0x0003C7EC
OS Version: 6.3.9600.2.0.0.256.48
Locale ID: 1033
Additional Information 1: 2760
Additional Information 2: 2760047ed5421604e1db972ffbec7da2
Additional Information 3: 4353
Additional Information 4: 435387dac57f5336874c418d6277d6ea
Also sometimes when resizing pages the text becomes granulated and it dissapears
Other video card driver from other company had same issue and it was fixed like is described here: https://www.sysnative.com/forums/windows-7-windows-vista/18327-stackhash-appcrash-issue-windows-7-sp1.html [SOLVED] Stackhash APPCRASH issue, Windows 7 SP1
I temporary found a fix, that proves it is the graphical driver or its components, by Enabling 64-bit processes for Enhanced Protected Mode in Internet Explorer Options, and not even a single error or text problems.
Also in game Fallout 4 after patch 1.2.37, till the last 1.5
textures and all other details are a big mess. Only lines and planes
Does it fail every single time, or only sometimes?
If you can offer a % rate please do.
Every single time
Hardware (HW)
Brand and Model of the system.
Mb Asrock Z170 Extreme 7+ i7 6700k
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
No other graphic card
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
EFP
How much memory [RAM] in the sy...
