22816 Discussions
BSOD with STOP error 0x00000116 in igdkmd64.sys every time XBMC Dharma (10.1) attemps to change the display refresh rate
I still have the same issue with the latest driver (2342). I get a BSOD with STOP error 0x00000116 in igdkmd64.sys every time XBMC Dharma (10.1) attemps to change the display refresh rate to match video fps.
My configuration:
* Core i5 2500K
* ASUS P8H67-M PRO (BIOS version 0902)
* Windows 7 Ultimate 64-bit SP1 with all updates applied
* HDMI -> Denon AVR-1911 -> Panasonic TX-P50VT20E
* 128M iGPU share memory size set in EFI/BIOS
* No overclocking of any kind, all speeds and voltages in default (auto) settings
I have no problems whatsoever with 2219 or 2291 drivers. Versions 2321 and 2342, on the other hand, crash every single time as described above.
I can reproduce this issue 100% in a fresh install of Windows 7, with or without SP1, both in 32 and 64-bit versions.
