23762 Discussions
Backlight not turning off doing powersaving
HLars1
I just bought a MSI Z87I and a Intel 4770K CPU with 4600 HD Graphic chip
I have a Apple LED Cinema screen connected to the board using the Display Port.
My problem is that when the screen turns off after 5 min, it goes black, but the backlight is still on. On my old computer an Intel DH67CF with a Intel Sandy bridge T Model cpu (cant exactly remember the same) with 2000 HD graphic its working just fine on Windows 7.
What I have tried on my new computer is the following
Tried different driver from Intel webside and manufactur webside - Same issue when powersaving
Tried to install both Windows 7 and Windows 8 - Same issue.
Tried to connect my LG TV using the HDMI cable - same issue on this screen, so its not related to my Apple monitor
I think the issue is related to Intel graphic driver.
Do others have the same issue and maybe a solution for it ?
/Henrik
DArce
Valued Contributor III
HLars1
I installed the 64 bit windows 8 driver from your link - same issue.
So here you have my 64 bit DXdiag report, hopefully it can help you determine the issue.
System Information
Time of this report: 9/15/2013, 19:36:05
Machine name: WORKSTATION
Operating System: Windows 8 Pro 64-bit (6.2, Build 9200) (9200.win8_gdr.130531-1504)
Language: Danish (Regional Setting: Danish)
System Manufacturer: MSI
System Model: MS-7851
BIOS: V1.2
Processor: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz (8 CPUs), ~3.5GHz
Memory: 8192MB RAM
Available OS Memory: 8068MB RAM
Page File: 2144MB used, 10530MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.02.9200.16384 64bit Unicode
DxDiag Previously: Crashed in DirectShow (stage 1). Re-running DxDiag with "dontskip" command line parameter or choosing not to bypass information gathering when prompted might result in DxDiag successfully obtaining this information
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4600
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0412&SUBSYS_78511462&REV_06
Display Memory: 1792 MB
Dedicated Memory: 32 MB
Shared Memory: 1760 MB
Current Mode: 2560 x 1440 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: LED Cinema
Monitor Id: APP9226
Native Mode: 2560 x 1440(p) (59.951Hz)
Output Type: Displayport External
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 9.18.0010.3257 (English)
Driver Version: 9.18.10.3257
DDI Version: 11.1
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: Thread
Driver Attributes: Final Retail
Driver Date/Size: 7/29/2013 21:28:52, 8653312 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4752-11CF-6B7B-5B58BBC2C435}
Vendor ID: 0x8086
Device ID: 0x0412
SubSys ID: 0x78511462
Revision ID: 0x0006
Driver Strong Name: oem4.inf:5f63e534dd898f5e:iHSWD_w8:9.18.10.3257:pci\ven_8086&dev_0412
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/...
MDora2
My name is Max and i have an Asus Z87-A with a Core i5 4670k using the intel HD graphics 4600.
One of my two display is a Sony Playstation 3D display ( http://us.playstation.com/ps3/accessories/sony-playstation-3d-display-ps3/index.html PlayStation® 3D Display with SimulView™ Technology | PS3™ Accessories -PlayStation® ) connected via HDMI and i am having the same issue. I do have to mention that there's no specific drivers for this one since Sony never really bothered to develop a driver for it. So the driver shows as Generic PnP Monitor in device manager. If i go in the information center of the Intel HD Graphics Control Panel, the 3 Power management support options are showing as unsupported.
If anyone has a fix on how to correct this problem, it would be very appreciated. I find it a bit unpleasant to have to remember to shut down the screen when i'm not using the computer. Having the backlight turned on can't be good on the long run.
Also, as my paste below will show, my Benq GW2450 (DVI) with Benq drivers installed, which is an actual computer screen, doesn't support all of the power management options. However, this isn't really an issue since it's properly going to standby when sleeping.
Any help would be greatly appreciated!
Report Date: 9/16/2013
Report Time[hh:mm:ss]: 11:10:38
Driver Version: 10.18.10.3262
Operating System: Microsoft Windows 8 Pro with Media Center(6.2.9200)
Default Language: French (Canada)
Installed DirectX* Version: 11.1
Supported DirectX* Version: 11.1
Shader Version: 5.0
OpenGL* Version: 4.2
Physical Memory: 16063 MB
Processor: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
Processor Speed: 3406 MHz
Vendor ID: 8086
Device ID: 0412
Device Revision: 06
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4600
Video BIOS: 2170.0
Current Graphics Mode: 1920 by 1080
* Devices Connected to the Graphics Accelerator *
Active Digital Displays: 1
Active Digital Televisions: 1
* Digital Display *
Monitor Name: BenQ GW2450
Display Type: Digital
Connector Type: HDMI
Serial Number: BNQ78BF
Gamma: 2.2
DDC2 Protocol: Supported
Device Type: Digital Display
Maximum Image Size:
Horizontal: 20.87 inches
Vertical: 11.81 inches
Monitor Supported Modes:
640 by 480 (60 Hz)
640 by 480 (75 Hz)
720 by 400 (70 Hz)
800 by 600 (75 Hz)
800 by 600 (60 Hz)
832 by 624 (75 Hz)
1024 by 576 (60 Hz)
1024 by 768 (75 Hz)
1024 by 768 (60 Hz)
1152 by 870 (75 Hz)
1280 by 960 (60 Hz)
1280 by 1024 (60 Hz)
1280 by 720 (60 Hz)
1280 by 1024 (75 Hz)
1280 by 800 (60 Hz)
1600 by 900 (60 Hz)
1680 by 1050 (60 Hz)
1920 by 1080 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 09 D1 BF 78 45 54 00 00
07 17 01 03 80 35 1E 78 2E 6B 35 A4 55 55 9F 27
0C 50 54 A5 6B 80 61 C0 81 00 81 C0 81 40 81 80
A9 C0 B3 00 D1 C0 02 3A 80 18 71 38 2D 40 58 2C
45 00 13 2A 21 00 00 1E 00 00 00 FF 00 38 32 44
30 30 33 37 31 53 4C 30 0A 20 00 00 00 FD 00 32
4C 1E 53 11 00 0A 20 20 20 20 20 20 00 00 00 FC
00 42 65 6E 51 20 47 57 32 34 35 30 0A 20 00 CF
* Digital Television *
Monitor Name: Generic Monitor
Serial Number: SCE0301
Gamma: 2.2
Device Type: Digital Television
Maximum Image Size:
Horizontal: 20.47 inches
640 by 480 (60 Hz)
800 by 600 (60 Hz)
1024 by 768 (60 Hz)
1280 by 720 (60 Hz)
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 4C 65 01 03 3A 5A 0F 00
21 15 01 03 80 34 1E 78 0A EE 95 A3 54 4C 99 26
0F 50 54 21 08 00 81 80 01 01 01 01 01 01 01 01
01 01 01 01 01 01 02 3A 80 18 71 38 2D 40 58 2C
45 00 0A 26 21 00 00 1E 01 1D 00 72 51 D0 1E 20
6E 28 55 00 0A 26 21 00 00 1E 00 00 00 FD 00 3A
3E 1E 50 11 00 0A 20 20 20 20 20 20 00 00 00 FC
00 53 43 45 49 20 4D 4F 4E 49 54 4F 52 0A 01 14
02 03 3B F0 50 10 1F 05 14 04 13 03 02 12 11 07
06 16 15 20 01 23 09 07 05 83 01 00 00 7A 03 0C
00 10 00 00 21 E8 15 15 15 15 90 0C 28 10 38 10
48 10 58 10 E8 10 06 16 E2 00 6A 01 1D 80 18 71
1C 16 20 58 2C 25 00 0A 26 21 00 00 9E 01 1D 80
D0 72 1C 16 20 10 2C 25 80 0A 26 21 00 00 9E 02
3A 80 D0 72 38 2D 40 10 2C 45 80 0A 26 21 00 00
1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8C
* Other names and brands are the property of their respective owners. *
DArce
Max_x2, could you please test using our latest generic driver and using the latest BIOS version 1405 from Asus*?
http://www.asus.com/Motherboards/Z87A/# support_Download_35 http://www.asus.com/Motherboards/Z87A/# support_Download_35
GZZ, could you please try removing the Intel(R) video drivers from the control panel and test again just to see what happens?
HLars1
I just uninstalled the Intel(R) video driver, rebooted and then tried it and backlight is still on.
Should I redownload and reinstall the driver again?
MDora2
Lol funny you should say that, i was just about to update the bios to 1405.
And what do you mean by "our latest generic driver"? Do you mean i should uninstall intel's hd graphics driver?
Max
MDora2
I'm now on Bios 1405. No change (as expected).
Please provide a new driver version that will take care of that issue, as it's reducing our display's lifespan.
Max
DArce
Max_x2, links to our latest generic driver was posted above when being offered to GZZ. Driver version 9.18.10.3257.
These URLs are:
For x32 bit operating systems:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23105 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23105
For x64 platforms:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23106 http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23106
GZZ, so the issue still persists even with Microsoft's generic drivers too. In that case allow me to further investigate on this and see what else we may try.
HLars1
I uninstall Intel driver, then windows says I'm using Microsoft Basic Display Adapter (Driver version 6.2.9200.16384) and my monitor is now Generic Non-PnP Monitor (Driver: 6.2.9200.16548) and the issue is still the same, no change at all.
So please advise me on what to try next?
DArce
Allow me to further investigate on a root cause for this and get back to you with an answer.
MDora2
Hi Diego,
I've tried the generic driver you suggested, and there's still no change. I'll be waiting for further instructions.
Max
HLars1
Something I also notice is that after the computer has been in sleep mode overnight and comes back, then my monitor wont sleep at all.
I have downloaded Nircmd - http://www.nirsoft.net/utils/nircmd.html http://www.nirsoft.net/utils/nircmd.html - and it has a command called "nircmd.exe monitor off" which does exactly the same as when windows turn off my monitor. But when running this command after a night in windows sleepmode the screen goes black for like 1 second before turning on again, so my monitor wont even sleep. The only way to fix this issue is to reboot my computer, then it will sleep again.
Offcourse this has nothing to do with backlight is still on, no matter what.
HLars1
I came a bit closer to a 'solution' as its not a real solution, but hopefully something usefull for the intel people to locate the driver error.
So what I did was to skip Windows 8 and try install Windows 7 64 bit. Just after install and without installing any driver/updates I tried my nircmd64 script mention in the above post. Backlight now turn off, so far so good. I then install the newest driver (ver 3257) and rebooted. I then tried again and this time backlight didnt turn off, as this was the >only< driver I installed, I am pretty sure the error is inside this driver. So I uninstalled intel driver again and rebooted and using windows 7 default driver backlight is turning off. So you might ask what driver does windows 7 use as default and this is what I got from the Device manager
Display Adapter
Name: Standard VGA Graphics Adapter
Driver Date: 21-06-2006
Driver Version: 6.1.7600.16385
Monitor
Driver Version 6.1.7600.16385
I hope this is useful in finding a solution to the problem.
DArce
Max_x2 and GZZ, could you please tested with the latest generic beta drivers for Win8.1?
This driver will work on Windows 7/8 as well, (3282). You can get it from the following links:
32-bit: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23195 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23195
64-bit: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23194 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23194
DIvan11
Hi, i have same problem to.
Motherboard MSI B85M-E33.
Intel Core i5-4670.
Monitor AOC i2269Vwm.
Win7x64.
Just installed the beta driver. The monitor goes into sleep mode and turns off the backlight.
MDora2
Hey Diego ,
BOOM! Problem solved. My Sony now goes into sleep, great work!
So i'm guessing the update will roll out soon. I'm very, very pleased to see such a quick problem resolution from Intel. Thanks a lot
Max
DArce
Max and Arboo, Thank you for your feedback on this matter, I'm forwarding this to the developers to make sure this is included in the next official release.
Thank you.
HLars1
Sorry for the delay, as my account was locked out.
I can also confirm that the beta driver is working just like it should with the backlight turning off. Also no issue with monitor sleep after computer has been suspended (sleep mode).
Thank for the support.
DArce
You are welcome GZZ and thanks for your feedback too. I have submitted all your information so this can be fixed in a future official release.
mSolo5
its now 3/2014, and I have this problem with the latest drivers
my monitor wont go to sleep...
and driver version is way ahead of that beta
(3496)
mitch
