23648 Discussions
Battlefield 6/Redsec Poor Performance on ARC B580
TheRealGordonFreeman
Ever since Battlefield 6 launched, specifically in the REDSEC Battle Royale mode I have had significant performance issues with the game. I cant seem to get above 70 FPS even when I'm on incredibly low settings and not even running at my full display resolution. I have a 1080p monitor with a 180hz refresh rate and I play a lot of Call of Duty: Warzone (a similarly demanding game) and I average 115-140 FPS on that game while not being able to crack 90 on Battlefield. And thats rare. Usually I average more  like 45-61 FPS.
I"m very used to playing games on 100+ FPS and believe my system has the power to run it, but I believe it might be due to incompatibilities with Battlefield's engine or my driver.
PC Specs:
CPU: Intel Core i5 12400F
GPU: Intel Arc B580 OC
Motherboard: MSI Pro B560M-P DDR4
PSU: 650w MSI MAG
RAM: 16 GB DDR4
XMP: Enabled
Graphics Driver Version: Latest
OS: Windows 11 Pro latest ver.
The graphics settings I use will be in the screenshots with this post. I use very low settings,
Ray tracing is not and has never been enabled
I play on 1920x1080p at 180hz
Only the latest driver versions number 32.0.101.8826, 32.0.101.8824, 32.0.101.8801, 32.0.101.8737 have been tested by me at this time.
I appreciate any help in this matter.
RichardC_Intel
Thank you for reaching out. I want to assure you that all the information you have provided will be instrumental in further investigating on this matter.
You will receive updates on the progress of this investigation. Please feel free to reach out if you have any additional information or questions in the meantime.
Thank you for your patience and understanding.
Richard C.
RichardC_Intel
Hello TheRealGordonFreeman
Just to confirm, have you tried the recommendation on this thread: Low fps :: Battlefield™ 6 Discusiones generales
Some user reported that EA overlay has something to do with the FPS issue.
I look forward to hearing if this recommended solution helps resolve the issue you're experiencing.
Richard C.
RichardC_Intel
I wanted to check if you had the chance to review the question I posted. Please let us know at your earliest convenience so that we can determine the best come course of action to resolve this matter.
Richard C.
RichardC_Intel
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Richard C.
