22809 Discussions
Blue Screen on Media Center DVD Playback with i3
I just upgraded a home-built PC to an Intel i3 Processor with built-in Intel HD Graphics connected to a Sony TV over HDMI. I've installed the latest, posted video driver from Intel however most times I attempt DVD playback in Windows Media Center on Windows 7 the screen freezes with macroblocking and then 10-15 seconds later I see a blue screen that the video scheduler encountered an unexpected error. When I do see normal DVD playback I've never been able to stop it and resume without seeing this behavior. Can someone tell me if this is a known issue? I'd be happy to provide extra info if necessary. If there's some chipset feature I could disable to work around this I'd like to know.
Also I noticed that during DVD playback in Media Center, the video gets pillar-boxed for some reason in a way that Media Center can't compensate for. I also see this in Windows Media Player. Other playback (RecTV, etc) and blu-ray via Cyberlink works fine.
Here's my diagnostic output:
Intel® HD Graphics (Core i3)
Report Date: 6/19/2010
Report Time[hr:mm:ss]: 13:9:14
Driver Version: 8.15.10.2119
Operating System: Windows 7 (6.1.7600)
Default Language: English (United States)
DirectX* Version: 10.0
Physical Memory: 3932 MB
Minimum Graphics Memory: 32 MB
Maximum Graphics Memory: 1696 MB
Graphics Memory in Use: 134 MB
Processor: Intel64 Family 6 Model 37 Stepping 2
Processor Speed: 3076 MHz
Vendor ID: 8086
Device ID: 0042
Device Revision: 12
* Accelerator Information *
Accelerator in Use: Intel(R) HD Graphics
Video BIOS: 1949.0
Current Graphics Mode: 1920 by 1080
* Devices Connected to the Graphics Accelerator *
Active Digital Televisions: 1
* Digital Television *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 2.2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 27.56 inches
Vertical: 15.75 inches
Monitor Supported Modes:
640 by 480 (60 Hz)
720 by 480 (60 Hz)
1920 by 540 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 4D D9 00 95 01 01 01 01
32 0F 01 03 80 46 28 78 0A 0D C9 A0 57 47 98 27
12 48 4C 20 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 01 1D 80 18 71 1C 16 20 58 2C
25 00 DF A4 21 00 00 9E 8C 0A D0 8A 20 E0 2D 10
10 3E 96 00 30 A4 21 00 00 18 00 00 00 FC 00 53
4F 4E 59 20 54 56 0A 20 20 20 20 20 00 00 00 FD
00 3A 3E 0F 2E 08 00 0A 20 20 20 20 20 20 01 29
02 03 1B 76 47 85 02 03 04 06 07 01 23 09 07 07
83 01 00 00 66 03 0C 00 10 00 80 01 1D 00 72 51
D0 1E 20 6E 28 55 00 DF A4 21 00 00 1E 8C 0A A0
14 51 F0 16 00 26 7C 43 00 30 A4 21 00 00 98 8C
0A D0 8A 20 E0 2D 10 10 3E 96 00 DF A4 21 00 00
18 8C 0A A0 14 51 F0 16 00 26 7C 43 00 DF A4 21
00 00 98 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 86
* Other names and brands are the property of their respective owners. *
Allan_J_Intel1
This problem does not seem to appear with graphics driver version 15.17.7.2141
Get this version here
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19130&ProdId=3231&lang=eng
